Page 207 of 210 FirstFirst ... 107157197203204205206207208209210 LastLast
Results 4,121 to 4,140 of 7539
    Mar 2007
    Quote Originally Posted by DAD525 View Post
    Sir Suysuy, sa labas ka lang yata nagpa park? . Baka meron na yan sa Banawe(if youre within MM or nearby). Sa mga online seller meron na yata nyan kahit using fog light cover for Monty word to search.
    Meron actually sa shopee 1,500 pesos nakita ko. Baka meron mas mura. Now ko lang napansin nawala na. Bumabaha kasi kadalasan baka natangay.
    Jul 2017
    Quote Originally Posted by suysuy View Post
    Ganun b.. malakas yung water current pag ganun.. Check mo mabuti pag sa online ka bibili kasi karamiran dun ay dinidikit lang sa oem cover. good luck
    Aug 2017
    https://www.topgear.com.ph/news/car-...-a962-20190913
    Earlier than expected.[emoji4]
    Sent from my iPhone X using Tapatalk
    Quote Originally Posted by montro View Post
    well, the rear saklays, as kags calls them, are shorter now.
    Feb 2009
    Meron na ba dito nag try mag lagay ng obd2 heads up display?
    Feb 2009
    Another question, isa lang ba talaga ang umiilaw na fog light sa likod? GLS owner here
    Quote Originally Posted by neoscythe View Post
    yes. sa left side lang.
    Jan 2020
    Normal yan bos..
    Guys ask ko sana if ma-vvoid ang warranty if
    1. Replace tail light assembly (genuine part) from GLS to GT led style?
    2. Replace bulbs of headlights to GT style?
    Both to be done outside casa para mas mura.
    Quote Originally Posted by Mcmanster View Post
    i don't think so.
    you didn't cut any wire naman, right?
    but if something did go wrong, as a result,
    it would be unfair to have casa fix it for free, right?
    Better check with the casa to make sure. But highly likely ma bo void yung warranty mo.
    Feb 2007
    I think, there are modifications that needs to be done to the wires. Its not plug and play. So your warranty maybe compromised
    Nov 2019
    Good day po! Ask ko lang po kung normal lang na ganyan yung shocks?. Yung parehong shocks sa likod ganyan po parang basa. Thanks po
    Attached Thumbnails Attached Thumbnails ab0eebd0-86b4-4975-8c4c-fca77bc315ae.jpg
    Jan 2008
    Quote Originally Posted by renzzzc View Post
    Sira na po yan.. replace na po
    Gen3.5 2020gt 4x2
    Apr 2012
    Quote Originally Posted by zix888 View Post
    Gen3.5 2020gt 4x2
    ayun oh, ang trademark na sapatos. may bago na naman ang Zix Performance [emoji106]
    Gen 3.5 pala, akala ko Gen 4 na[emoji4]
    Need advise mga paps, wala kasing lumalabas na tubig sa rear washer ni monty 2016. Meyron naman sa harap. Nagana din wiper. May tubig din naman sa washer fluid reservoir. I always used distilled water po. Ano kaya problem?
    Sent from my SM-G920I using Tapatalk
    Apr 2012
    Quote Originally Posted by bongliza View Post
    try mo sundutin yung butas at linisan, baka barado lang ng tumigas na mineral deposits
    isa lang yun lng washer motor. if there is water in the front. then it could just be a clogged nozzle or worse, a pinched hose. i would suspect some pinching around the lift gate area.
    does the pump motor work?
2016 Mitsubishi Montero
