Page 199 of 210 FirstFirst ... 99149189195196197198199200201202203209 ... LastLast
Results 3,961 to 3,980 of 7539
    Sabi nila the looks of a car will grow on you. Pero talagang ayaw eh. (Montero rear design)
    Mar 2013
    Dapat sinama nila ang tail light sa face lift, something similar with xpander's tail light is nice.
    Mar 2007
    Hello. May naka experience ba dito walang fluid lumalabas sa washer/wiper both front and rear? Puno naman yung washer fluid. Biglaan lang ayaw na gumana or walang lumalabas. Also I cant hear the whirring sound when you activate the washer. Busted motor?
    Sent from my SM-A605G using Tapatalk
    Dec 2011
    Hi Everyone, I tried playing around on my TPMS and end up having signal lost on all tires. Di ko na maibalik. It started when i press and hold the hood in the monitor then when I press and hold the tires, isa isa nang nag blank indication. As per manual during signal lost indication will return after 20 min. Did not happened. Help please. My unit is the stock head unit for 2107 gls prem.
    Quote Originally Posted by suysuy View Post
    have you checked sir yung fuse?
    Mar 2007
    Wala pa. If its blown then may something wrong. What could be the cause? May nabasa akong post dito pero rear washer problema niya. Sakin both kasi. No audible whirr.
    Yes, there’s no harm in asking for discount...
    For sure meron yan kasi inhouse... [emoji4] pero make sure to copy your totAl amount paid before the discount so you can compare... mga marurunong yang mga agent, babawian ka sa monthly... hehe...
    baka 10k discount lang ang ending though infront sasabihin na 100k hehehe
    these guys are experts at hiding expenses.
    they can give you a 100K discount up front, but when you compute the monthlies etc, regular price pala ang sum total.
    go over the payment scheme with a fine tooth comb and a good calculator.
    and have available, figures from previous non-discounted schemes, to compare against.
    even cash purchases can be made to look "discounted".
    50K discount nga, but the formerly-available free 1 yr compre and LTO are not there anymore.
    that is, if you are counting on the discounts to help decide for you, what to buy next.
    Apr 2018
    Thanks for the suggestions/advices.
    Sorry cant help but I want to share my computation... eheh to check if I did it correctly or not
    Thanks again, really learning a lot.
    Nasa 300+ page napala na ko ng thread na to...
    Oct 2009
    Quote Originally Posted by ged View Post
    Unreadable bro..
    Sent from my iPhone Xs using Tapatalk
    Jan 2017
    2017 Montero model.During 10k and 20k PMS my tire rotation na kasama, napansin ko lang hindi nila binabalance pagkatapos. Ok lang ba yun?
    why are the insurance figures' differences not commensurate to the differences in car price?... same with the mortgage fees...?
    are they rounded figures?
    Most likely expansion valve, mahal pala ng labor no
    Sent from my SM-A720F using Tapatalk
    Nov 2017
    Kung expansion valve papalitan na yan ng bago at definitely magtatapon yan ng freon then saka kakargahan uli. Hayaan mo na mga aircon shop gumawa nyan.
    Apr 2010
    Napapalitan po ba ng HID yung sa montero premium or not? medyo nahihinaan kasi ako sa stock led kahit na light tint lang windshield ko.napakalayo sa quad projector retrofit ko sa isang car.
    sabay ko na din ask, if nasa D ba yung kambyo ay gagana yung paddle shifter if accidentally napindot ko yun?yesterday kasi accidentally nagalaw ko, then ayaw umangat nung gear kung di ako nag + sa shifter (nasa D ako). naging ok lang ulit nung nagfull stop ako.
    wala din po ba talagang sound ang lock/unlock ng doors sa 2018?kasi yung sa friend ko tumutunog siya once nipress ang lock or unlock not sure lang if 2017 model yung kanya.
    Aug 2017
    Quote Originally Posted by tribal View Post
    1. You can change it by retrofitting. Send your monty to reputable retrofitting shops.
    2. If you're in D the paddle shifters activated once you hit it. It will return back to regular D if fully stop or put your shifting knob to the left and return back to normal.
    3. 2018 models removes the alarm except in GT variant.
    Sent from my iPhone X using Tapatalk
    Apr 2010
    Quote Originally Posted by montro View Post
    Thanks Sir Montro for the info.
    for number 3, can you recommend a shop for alarm installation?
    Aug 2017
    Try to contact wintertime on this as they are the authorized installer of Mitsubishi
    Sent from my iPhone Xs Max using Tapatalk
    k
    I think it will also return to regular D if you press the paddle shifter (+) for a few seconds....
    Aug 2017
    Never been tried bro. Will try this one.
2016 Mitsubishi Montero
