Page 173 of 210 FirstFirst ... 73123163169170171172173174175176177183 ... LastLast
Results 3,441 to 3,460 of 7539
    Mar 2004
    Quote Originally Posted by boyduwal View Post
    Is there a way to drain po yung nailagay kong tap water?
    Thank you Sir.
    Get a long plastic hose and suck the water out ...
    Oct 2017
    Mga Sir newbie po dito sa forum ok lang po ba kung tap water ang nailagay ko
    as washer fluid? got our monty 2017 last month. Thank you po.
    Nakapag 1000 Km PMS ka na ? What are the job orders done ?
    Sent from my SM-G950F using Tsikot Forums mobile app
    Oct 2017
    Quote Originally Posted by Raynim999 View Post
    negative pa sir 110km pa lang tinakbo.
    Oct 2017
    Ayos ah..1 month na..100+km palng
    i use ordinary gripo water in my non-mitsu vehicle.
    12 years.
    it hasn't clogged yet.
    if you don't want to bother with the plastic hose, you can pump out the tap water by engaging the windshield cleaner motor, until the reservoir is empty. then, you can pour in your liquid of choice.
    Mar 2004
    Try not to do this ... it will overheat the motor pump ... another issue with using tap water as windshield washer is water marks ...
    Oct 2017
    Mga sir.. malikot ba tlga si monty? Glx manual 2017 po unit ko.. ibig ko po sabihin magalaw parang duyan?
    you can ask your nearby detailer for scratch buffing... sandali lng yan.
    Oct 2017
    Hello sir! Thx sa reply.. normally mga magkano namn kaya gagastusin nyan sir?
    Aug 2017
    Quote Originally Posted by sundae 74 View Post
    Not much compare sa participation fee na ibabayad kung padaanin mo sa insurance.SE is right go to nearest detailer in your place.IMHO more or less 3k.depende sa sukat ng nadamage
    Oct 2017
    Quote Originally Posted by montro View Post
    Detailer means car dealer? Sorry sir.. newbie pa kasi ako.. it's my first car.. sa sedan ako ng practice.. na bagohan ako sa suv.. kaya palpak estimate ko.
    May scratch pala na sobrang deep na labas na ung metal.. around 1-2 inches ung length.. the rest, cguro superficial lng..
    Not casa/dealer, but a shop specializing in body repair/paint maintenance.
    Sent from my SM-G930F using Tsikot Forums mobile app
    Aug 2017
    Montero 3rd gen has designed for a softly tuned suspensions.
    Oct 2017
    U mean to say na sadyang duyan ang feel nya sir?
    Aug 2017
    Since your using a sedan previously and a first timer on ppv medyo maninibago ka sa una. First mataas ang montero compare sa sedan. Second montero has a truck design chassis it means medyo rugged ang dating. There is many more difference in riding comfort sa sedan at sa ppv, thats why before we bought a new car we need to drive test for a different car brand,car model and budget to select what is fit for your comfort,needs,safety,etc.. masasanay ka din bro sa una lng yan. Check your tire pressure din baka below sa recommended 29psi front and 31psi back.
    Oct 2017
    Noted sir!!! Ganda tlga ng forum nato! Malaakijg tulong
    Aug 2017
    Mystique Blue.
    Aug 2017
    Hirap maghanap ng ganyang kulay for glx variance bro.
    Nov 2003
    Medyo kaya naghahanap ako kung saan may avAilable d lang ako masyado sa automatics feel like naglalaro Ako eh kaya manual gusto ko
    Aug 2010
    Hi, just got my gls premium a few weeks back. Has anybody experienced losing sound while listening to the radio? It's like putting it on mute for 3 to 5 seconds and goes back to normal. Does the head unit need updating from winter pine? Thanks
2016 Mitsubishi Montero
