Page 162 of 210 FirstFirst ... 62112152158159160161162163164165166172 ... LastLast
Results 3,221 to 3,240 of 7539
    32psi couldn't tear open the aluminum alloy rims like this. Air will just leak out if the rim is defective.
    Quote Originally Posted by Bill View Post
    It's a tire issue in my opinion. I had the same experience with Dunlop tires with my Civic 10 years ago.
    Mar 2013
    Mahina ang construction ng oem rims
    Quote Originally Posted by ClaNker View Post
    Mas nakakatakot tuloy mag OEM copy na 20" wheels.
    Quote Originally Posted by ssaloon View Post
    Buying OEM-copy rims isn't any riskier than buying cheap aftermarket rims. Both aren't held to the same quality standards as OEM or high-end aftermarket rims.
    Granted, even Chinese/Taiwanese knockoffs are still made from cast alloy molds so it takes a lot of stress to damage even cheap rims, but as always, caveat emptor.
    Do you honestly believe that all the replicas sold in Banawe and Evangelista have gone through the same testing as the OEM rims from car manufacturers themselves?
    I have nothing against copy rims - I would probably get another set if I couldn't find nice OEMs for my car. But I make that decision knowing that I didn't get the sturdiest option.
    Jul 2017
    correct delikado pala yan lalo na if you running too fast
    OEM rims are sturdier than knockoffs from China and Taiwan. Save for Rota, most rims that you find in Banawe and Evangelista are Chinese copies of original rims which don't have the strict QC of OEMs.
    I've been lucky with my copy rims for my previous car, but I chose to go for higher quality Enkei OEM rims for my current car. Hard to say how much sturdier it is since you only really find out in an accident, and I wouldn't want firsthand experience with that.
    This case was obviously a matter of driver error, where the driver hit a gutter or some other sharp object at an angle, going past the tires and shredding the rim. I saw this firsthand when my friend who was in a convoy with me accidently drove past debris from a damaged car on NLEX - it flattened 2 of his tires and bore a hole in one rim. It wouldn't have been any different if he were using aftermarket rims.
    Aug 2017
    Ano kaya isasagot ni mitsubishi? ff
    ^ sino ba ang manufacturer ng oem rims ng latest gen na monty ?
    Iyong sa honda kasi lahat ng oem rims enkei made. At least yong mga honda namin na dumaan sa amin ganoon
    when you look into the abyss, the abyss looks into you
    Jul 2017
    From the looks of the tire and yung mga gasgas sa fender mukang nasabit sa gutter. Yung pagsabog ng gulong pwede nga mangyari but I think yung crack sa wheel is from running it flat then rolling on something. Just my two cents...
    Jul 2016
    Ang sabi ng victim may sumabog muna bago sila na bungo. Then upon inspection wala tama yung tire. Yung rim ang nag cause ng pag sabog not the tire according sa statement ng victim. Kung tama yung statement nya baka rim nga ang defective or may iba pa nangyari.
    Sent from my vivo 1606 using Tsikot Forums mobile app
    Oct 2014
    Tanong ko lang mga sir, if pwede bang malagyan ang 2017 GLS standard ng ESC?
    Sent from my E6833 using Tsikot Forums mobile app
    Jul 2016
    Quick answer is YES.
    BUT, you need to verify if you have all the needed modules/sensors(YAW rate, accelerometer, pitch and roll) to enable ESC feature.
    You can ask zix, I think He has the proper equipment to check it for you.
    Expect to spend minimum of 100k pesos siguro including the labor, wiring and needed modules.
    Oct 2014
    Quote Originally Posted by Janemar View Post
    This is my future project/gift kay monty sir, pag mag isang taon na siguro. Nakuha ko unit ko for 1,620,200 less 95k at free insurance sa bank.
    Premium sana kunin ko pero kailangang kong maghintay pa at talagang walang available sa casa that time. Besides, 2 weeks lang ang leave ko. Pag hinintay ko ang premium posibleng ibang tao ang maka una drive nito papuntang bahay.[emoji2]
    Ok na sa akin na may ESC kahit hindi pareho airbag number.
    Anyway salamat ng marami.
    P.S. Sino si zix?
    Jul 2016
    P.S. Sino si zix?
    Eto sir, better ask him na lang sa project mo.
    Zix Performance
    Usually casa is no good with that, either bebentahan ka nila bago unit or will say na its impossible without even looking or touching your unit. Hehe..
    From my little experience, Electronic stability control, hill start assist, hill descent control, brake assist, traction control, torque vectoring control, etc... are all found in ABS module. Usually, needed inputs are,
    1. Steering wheel angle sensor
    2. YAW rate sensor
    3. G-force/accel sensor
    4. Brake pressure sensor
    5. Wheel speed sensors accel pedal sensor (this is given since meron na si monty sa standard.)
    Malay natin it is just "deactivated" from planta and no hardwares needed. Hehe..
    Good luck!
    Oct 2014
    Zix Performance
    2. YAW rate sensor
    Good luck!
    I really like this forum, wide range of people with great ideas!
    Salamat sa ulitin.
    ESC is either integrated on the Airbag Control Unit or as a separate sensor. You may confirm it with Mitsubishi. Then you might have to re-configure the ECU since it has to interact with the EBS.
    its for both at and mt...
    its for faster response or better fc...
    RACECHIP Response Control - YouTube
    Nov 2007
    Any of you has a faulty DRL too? My DRL on the passenger headlight got busted and is for replacement of the whole headlight. Casa has already ordered the part.
    Ok lang sa akin that they fix the DRL but apparently they cant and just replace the whole thing. This is a rare time that I want them to fix just the faulty part and not replace the whole headlight assembly.
    Caveat lang is matagal daw ang dating ng parts. Let's see how many weeks or months
    Quote Originally Posted by JJB View Post
    O wonder how many days too. I'm guessing less than 2weeks
2016 Mitsubishi Montero
