Yes. Wala pa kayang solution mga casa sa issue na to? Last time i asked never heard daw sila regarding it.
Not all montero got the issue of steering column as per mitsubishi two ang nagprovide sa kanila ng parts ng steering column and yung isa ata is yung ang may issue. Yung gls ko ala naman issue ng steering column
Just upgraded my Cabin filter to K&N. malilinis kuna kahit quarterly o monthly(Kung sinisipag). Ang dumi talaga ng hangin natin sa metro, 6mos palang yang filter na yan. Tsktsktsk
*jigeloh
Sir where did you bought the knn cabin filter?
Thanks
Guys, patulong naman. Recently posted here my 2017 GLS Monty íssue/erratic rpm (1-2 lines) during traffic, while on Drive and Im stepping on the brakes. Got it check in two separate dealers, and walang sila findings. They did SQIL and yung sa transmission, ok daw cya. The 2nd Casa/dealer even showed me other units/stock (bnew) and meyroon din ganun. Paki-chech naman mga units nyo if meyroon din, usually nangyayari kapg na traffic ako, apak sa brakes, angat sa brakes, apak sa brakes, hindi ko nakukuha malagay sa N, naka D cya. . It will take mga 2-3 release brake and brake. Thanks!
Note: hindi cya palagi, paminsan-minsan lang.
Hi bro monty_gtv, tama ba, ito yun YT account ni bro zix - "gtv2011ph"? yung nakita ko na post niya pang gen 2 pa kasi.
Pero meron ako nakita na thai YT pang mitsubishi triton/pajero sport - ??????????????? MITSUBISHI TRITON and PAJERO SPORT | Cabin Air Filter Replacement - YouTube
Mukhang same lang naman ng itsura pero left side nga lang yun glove box/cabin filter location. Meron pala ito parang pnuematic cylinder kaya pala smooth kapag binuksan.
Yeah, its the same way. Experienced ko medyo hard to push lang yung cylinder mechanism, kaya puwede mo rin
dukutin sa taas once the glove box is at open/down position. Pagtanggal ng cylinder mechnism, then you can pull
upward ang pagtanggal ng glove box. Tsaka you have a good enough space to remove the cover and replaced your cabin filter.
Meron na ba sa inyu naka pagkabit ng turbo timer sa Montero GLS premium? Anung brand?
Sent from my Lenovo A7000-a using Tapatalk
