Ito mga sir yung level sa dipstick. Malayo pa yung level sa x mark.
Sent from my LG-D855 using Tapatalk
madami oil mo dpat hanggang dun lang sa second hole
Usually 1liter to 500ml ang difference ng low level and max level so based dyan sa stick mo overfilled sya by 1Liter... Not good.
Causes ng high oil consumption for new engines could be panget break in. Di nag seat ang piston ring sa bore causing high blow by than normal. Ung oil mist na blowby sa intake manifold napunta at sunugin ni engine, in a way nag coconsume ng oil engine.
Pwede rin na di pasok sa specs ni engine ang oil volatility standard ng oil na gamit mo. Meaning madali masyado mag evaporate ung oil mo kaya mabilis magbawas level sa dipstick than normal...
Lastly, engine design... Mahirap na maprove yan knowing mitsu engine designers na kalaban mo pero who knows...
Sirs question lang, how do you go back to Drive or "D" after using paddle shifters?
Sent from my vivo 1609 using Tapatalk
has anyone using wheel spacer here? how's the ride ? does affect ride comfort and steering ?
any suggestion on which thickness spacer is going to be best on our monty?
Mitsubishi Montero Sport 4x4 Diesel 2017 UNBOXING #NetUAutos - YouTube
Hi, do you know how big of a discount the dealer usually gives for the GT model? I read somewhere here mataas talaga, does it also apply to the 2017 kaya?
Good am sirs, pa post naman po ng biggest discount offers na nakuha nyo for 2017 GLS AT Standard na for bank financing at kung sinong dealer na din po sya. Thanks!![]()
My dealer is from Caloocan. I'll PM you her contact no.
Guy's do anybody knows what's the status on the steering column knock issue?
Also do you experience the sudden transmission downshifts during low speed?
Thanks!
No steering column knock on my Monty GLS.
Sent from my SM-G920F using Tsikot Forums mobile app
Thanks![/QUOTE]
minsan...
Sent from my Nexus 7 using Tapatalk
