Got it[emoji17]
Baka nga nagmamadali kasi ako di ko nilinaw so I need to remove the visor to get a full tint in front [emoji30]
usually 1/4 windshield lang free, *Walter is correct, to cut cost.
Mas ok sana kung pina full mo na para sabay sabay na. Pero since nandyan na, ipa full mo na lang madali lang tanggalin ng tint installer yung existing baka 2 - 3 hours tops, kasama na pagkabit nung bago. Tamang tama din, go vkool kahit sa front lang, sa experience ko e mas ok talaga kesa 3m.
Maiba ako base sa measurement ko mga 10 km per liter ako sa FC gls premium that is reset ang travel meter every time nag full tank automatic. Turbo diesel gamit mga 4 times ko ng ginagawa. [emoji16]
Maaliwalas na panahon [emoji33][emoji33][emoji33]
Guys , totoo ba na timing chain ung bago Monty? And how does that translate? Mas durable ba?
Sent from my Lenovo Z90a40 using Tapatalk
Auxiliary or mechanical fan has nothing to do with the timing type of the engine. It has something to do withe positon of the engine. Most car engine that is inlineor position from front to back of the car has mechanical fan and positoned left to right or termed "balagbag" are auxiliary fan. Inline wngine are mostly rwd and balagbag are fwd. i have several cars that is fwd runs on timing chain like tucson carens elantra timing helts on mazda 323, lancer while rwd on timing belt like strada innova l300. And there are also timing chain and gear or even pushrod on rwd. The isuzu mux . Nissan eagle. Isuzu elf.kia kc 2700 and hino. Soon monty 2016. Among all the timing Type. The belt is the quietest. But the earliest to be replace. 100000km required on most manufacturers. Then comes the timing chain. But a liitle longer than belt depend on the quality of oil you use. It gets noisy after sometime. The timing gears are almost in destructible but the engine will be heavy.
Mas malimig at mas tumatagal lang aircon pag timing chain kasi engine napatakbo sa main fan
Sent from my Macbook 12"
It has also nothing to do with the aircon. Generally the aircon performance is basebon the compressor . Evaporator and consenser. The condenser are usually located in front of radiator. For linear positioned engine the mechanical fan is always on while the engine is running. And some condenser are have extra aux electrical fan when aircon is turned on. Aux fan have more maintenance than mechanical fan.
Ingat sa biyahe this coming holidays
Guys, may idea po ba kaya kung more or less the same lang PMS cost ng Montero Base MT vs MU-X 2.5 MT? Currently PMS cost na lang deciding factor ko. Sa cash price at least 60k cheaper yung monty vs mux pero baka sa pms naman ako mapapagastos. My plan is to keep the car for at least 10yrs. Casa maintenance for at most 5 yrs, tapos sa labas na after.
Sa site ng isuzu, parang may kamahalan pa rin yung pms estimate.
Periodic Maintenance Service | Isuzu Philippines
Ang 4n15 ba ng monty may egr pa din? Thought with introduction of mivecs replaces the egr for Nox production
