Results 4,251 to 4,260 of 7539
March 26th, 2017 09:37 PM #4251
- Dec 2012
- 215
March 27th, 2017 06:31 AM #4252Saw someomes post on FB. Nkapaginstall n sya ng surround camera / birds eye view monitoring. Last time checked sa winterpine wala pa daw sa pinas yung ganun feat. Dami na nagiinquire info dun sa FB user pero wala binibigay tip. Anyone knows saan meron nito?
- Dec 2012
- 215
March 27th, 2017 06:33 AM #4253I saw someones post on FB. Nkapaginstall n sya ng surround camera / birds eye view monitoring. Last time checked sa winterpine wala pa daw sa pinas yung ganun feat. Dami na nagiinquire info dun sa FB user pero wala binibigay tip. Anyone knows saan meron nito?
March 27th, 2017 08:21 AM #4254
Speaking of camera, is there a way to change the color settings of the backup cam? Nalalabuan ako comparing it to my Mazda 3. Halos black and white na siya.
- 61
March 27th, 2017 09:14 AM #4255
March 27th, 2017 11:32 AM #4256
To current owners of montero,
Do you tend to forget to release the park brake every now and then because its no longer a lever switch?
Sent from my GT-P3110 using Tsikot Forums mobile app
- Mar 2017
- 150
March 27th, 2017 11:55 AM #4257Yun din concern ko for the new owners ng naka electronic parking break. Aandar ba ng pilit pag kunwari naka engage tapos nag gas ka like sa lever type? O hindi talaga siya aandar na parang naka neutral ka na umapak sa gas? Curious lang.
- Nov 2005
- 311
March 27th, 2017 12:34 PM #4258aandar syempre like a normal parking brakes would. I don't forget because I made it a habit ever since not to begin driving when I see any warning light lit.
but I can see others having a greater tendency to forget. I'm not much of a fan of electronic parking brakes(and push to start) but I appreciate the coolness factor.
siguro ang advantage, always same level of pressure all the time. unlike yung mechanical na may tendency to be pulled too hard (or too little) at times.
- Jan 2013
- 1,851
March 27th, 2017 12:46 PM #4259Like any other new thing, Sa umpisa you have to remind yourself of the electronic park brake. But eventually you'll get used to it especially if you drive the Montero on a daily basis.
Ako naman ang problema ko, minsan i look for the electronic park switch even when I'm driving the other vehicle which has the traditional lever. And vice versa.
Sent from my ONEPLUS A3000 using Tapatalk
- Mar 2017
- 150
March 27th, 2017 12:48 PM #4260I see. Ano kaya reason why hindi nilang ginawang ma bypass yung pagapak mo sa gas while on drive. For me, dapat siguro pag naka engage yung parking break kahit anong gas mo dapat di aandar. Dapat parang naka neutral lang tapos nag gas ka yung response ng car.
Thread was made nung 2018 pa po sir.
