Page 94 of 104 FirstFirst ... 4484909192939495969798 ... LastLast
Results 1,861 to 1,880 of 2693
    Quote Originally Posted by MONTY_PYTHON View Post
    Pero sir, hindi po ba ang Pajero ay hindi pa CRDI, di tulad ng mga Montero natin?
    I have intentionally posted this query in this thread having in mind the characteristics of Montero fuel system, and its supposed "problems". Given these factors, I was hoping one could chime in, for us to explore the feasibility of installing one.
    Matagal ng CRDI ang pajero kahit nung wala pa ang montero.
    If i were you, i'll just try to gas up using the euro4 diesel at hindi bahain yung lugar ng gas station.
    Dec 2009
    [QUOTE=MONTY_PYTHON;2616394]Maybe OT, my apologies in advance.
    Anyone here entertained the idea of putting another Fuel Filter for the Montero?
    The idea is not exactly novel as some already done it on some other vehicle. I am only curious if it can be done with the Montero. Internet searches reveal that there are two ways it can be done:
    1) Tank --> Additional Fuel Filter --> Factory Fuel Filter --> Suction Pump --> Rail
    2) Tank --> Factory Fuel Filter --> Additional Fuel Filter --> Suction Pump --> Rail
    Which Kit? Primary or Secondary?
    If i understand correctly, with the first method, it is recommended that the Additional Fuel Filter be a free-flow filter with lesser filtering ability than that of Factory Filter so as not to stress the Suction Pump. On the second method, the recommendation is finer filter after the Factory-installed filter ( I don't know what will be its effect to the SCV, if any).
    Care to share your thoughts, gents?
    kung serious ka about protecting your high pressure pump and CRDI components sa contamination both in particles and water isa lang solution dyan, use a highly efficient yet superb micron rating filter set-up na custom. the stock filter is just not up to the job kung gusto mo ng better.
    you have to use a fleet filter like baldwin/fleetguard... the best filter makers in the world.
    you just need to be willing to modify some fuel lines and space sa engine bay, even a single fuel filter basta maganda ang specs is already enough.
    baka ganito nasa mind mo>?
    i have installed one sa everest namin, more than 5 years na ganyan ang set up ko.
    if your going to use 2 filters you might stress the high pressure pump, unless you will put an inline pump. by doing that it will get complicated,
    although for the montero i don't think the stock filter is restrictive so a secondary filter could work since mababa micron rating ng stock ng montero compared sa fleet filters.
    Feb 2014
    Quote Originally Posted by Gabriel_Lorenzo View Post
    Bro saan ka nagpalagay ng sunroof?
    kasama na yan sir sa Gls-V 4X2 SE (special edition). . .
    Nov 2014
    Mga sir,tanong lang pano ba i disable ang alarm?kasi pag nagpapa car wash ako nag automatic siya eh kay lagi ako nakabantay para idisable. TIA
    Sir just switch your car to ON then push the red button on the lower left side of the dashboard panel, the red light will then appear. then do the same to enable the alarm. The red light will turn off
    Nov 2014
    Thank you jre.3368 masubukan nga bukas.
    xvanguish *ZIX
    oem rear foglamp
    volution full auto turbo timer
    arrow led turn lamp
    Feb 2013
    Good day mga master, need your expert advise. Nasabitan ako sa parking last weekend. Medyo malalim eh, ramdam ng kuko. Ano kaya maganda gawin para bumalik sa dati. TIA
    Feb 2013
    Good day mga master, need your expert advise. Nasabitan ako sa parking last weekend. Medyo malalim eh, ramdam ng kuko. Ano kaya maganda gawin para bumalik sa dati. Baka meron din po kayo alam na detailing/paint shop, around Sta. Rosa or Binan Laguna na pwede magpagawaan. TIA
    Nov 2014
    Mga sir question lang paano iaupdate yung memory card ng gps natin?kasama kasi yun sa freebies last year nung kinuha ko hangang ngayon di ko pa siya na update.may kailangan ba akong idownload or kailangan ko ipa update sa kanila? TIA
    Quote Originally Posted by stv09 View Post
    bro kung ayaw mo bumayahe ng sta. mesa para paremedyohan yung madidistort mong gps pag nag diy ka ng update, i suggest huwag mo na galawin. reminder, recent update cant be done at home, unlike before. winterpine lang nakakapag update niyan.
    Jan 2014
    Quote Originally Posted by zix888 View Post
    yeah... i just found it recently last night... you can not DL the update anymore..
    although meron naman instruction sila for manual update? ang gulo ng INAV!
    Jan 2014
    guys, baka may naka abot pa sa inyo ng Update file.... pa share!
    Jan 2009
    minor upgrade nudge bar and fog lamp
    Nov 2014
    Yung Version 2015-Q3 po? Na manual update ko pa naman sa akin nung September. Nag eerror minsan. Need to restart daw, pero hindi naman na distort ang map.
    Mar 2016
    Sir zix ano ba ma sasuggest mo ? Yun gps ko kse biglang di gumana.. ayaw basahin yun card. Paki pm din ng CP number mo at location ng shop mo. Thanks
    Nov 2014
    Sir zix888 good to hear from you again [emoji16] tnx sa info. Kakauwi lang kasi kaya nag iisip kung ano pwede gawin sa sasakyan. Pm naman ng price ng cruise control na manibela
    Oct 2015
    Sir zix888 kindly PM me the price of ff:
    EGR Blanking
    AC Filter
    OCC
    K&N Filter
    I'm planning to visit your shop holefully soon. : ) thanks..
    Quote Originally Posted by seabournlegend View Post
    good for you, if that is the case.
    Jul 2005
    iNav Q4 is out. Ok na kaya ito?
2014 mitsubishi montero
