sir longrun, adding 2T is by preference lang and not compulsory. you can give it a try and observe if there is difference in your engine noise, vibration, exhaust...etc.
refer to similar thread...http://tsikot.com/forums/engine-fuel...il-fuel-79879/
Sa bigat ng steering eh masasanay ka nalang sir. Pwede mo rin itaas yung tire pressure mo para lumambot steering mo sir. Pero pag tagal eh masasanay ka narin sir. About sa glsv gtv issue talaga yang turbo lag. Kaya ang iba naglalagay ng sprint boosters or performance chip like rcp/ unichip. Meron ding iba diyan nag upgrade ng fmic nila hehehe! * boss zix wala pa ba epektos natin diyan?
Hi Tsikoteers,
Took a leave last Thurs to have my Monty cheched. A technician from Mitsu Marcos Hway went with me to NLEX to check this. He was surprised of the loud wind blowing sound. Currently, they are still investigating this.
I shared the status here to check if you also encounter it with your Monty 2014 model. My brother also bought 2014 and also experienced the same. For us it is not normal and quite alarming. Technician already reported it to MMPC.
Hope someone from this 2014 thread could also share his/her experienced if encountered it. Thanks in advance.
Hi sir LR,
Have you checked if the window rubber seals are all ok? That includes the rubber around the windshield.
This might not be the case but this just give me a hint since it happened to me once(not a montero though). One of the "rubbers seals" was folded..
Sent from my Nokia5110 using Tapatalk Pro
Hi Sir Prince777
That is the initial assessment of the technician who went with us in NLEX. He was just surprised that he can hear it from all the doors. When we get back, he checked the rubbers and he said that it is fine.
As interim solution, he sprayed silicon to all the rubbers to soften it. Medyo na-reduced nman when my family went back to Bulacan on the same day. But the next day ay malakas na nman. Hope they can find the cause. I will share here the report once received from them. TIA.
Sir Zix888,
Pls PM me your mobile number. Interested in optitron, Egr and OCC. Thanks
mga sirs, mas ok ba ang Jetti disel para sa mga Monty natin? i mean compared sa Shelll, Caltex, Petron. TIA![]()
If your planning to install occ gamitin mo yung pwede mabuksan sa itaas para malagyan ng baffle since almost all occ are hollow inside especially the cheap ones I have mine installed cusco brand sealed type useless sya labas pasok parin yung langis transparent hose kasi gamit ko kaya kta ko yung langis sa outlet at inlet hose. After searching through the net i decided to make my own occ with 3 layers of screen between them i will place a steel mesh and air filter to ensure a clean air.
Sent from my iPhone using Tsikot Car Forums
Quote Originally Posted by marcnmark2 View Post
Greetings
this is your admin at MSCP forum please bear with us that we are doing our best to facilitate all your request regarding your account approval.
please check the following forum names that was approved.
torpydoo
boytsiks
redj14
jdgabriel
sonny with 10 post
sir marcnmark2 or any mscp officer please help, ask ko lang approve na ung account ko(mar04 din) sa mscp forum kaso may ibang threads ako hindi mabasa/access. Wala pa daw ako permission to access ung board e marami pa naman akong gustong basahin. In short very limited lang ang nababasa ko na threads. pls help. TIA!
2 days waiting for our ms. The SA said it was in transit ( from Bauan Batangas) to be delivered sa mitsu manila bay :/
