Page 81 of 129 FirstFirst ... 317177787980818283848591 ... LastLast
Results 1,601 to 1,620 of 3938
    Jul 2015
    The same thing happened to me yesterday. I tried clearing the fault twice using Torque2 unsuccessfully, but it disappeared by itself on the third cold start. It mentioned something about grey codes needing several attempts. Maybe it's time to change transmission fluid?
    Quote Originally Posted by the_mechanic View Post
    were talking on the same language pala sir. hehehe. (sensya na po mga ka-tsikot - OT). see you soon sir.
    Just to share the improvement made by K & N to my ride, you can see talaga the difference on accelaration between stock and the less restrictive air filter. Thanks sir zix for sharing the additional mods.
    thanks din sir!(dried mangoes)
    Quote Originally Posted by Polar88 View Post
    maraming salamat kay sir zix888 sa pag install kanina ng cabin air filter along Bocaue Tollgate
    thanks din. reserved na yung k&n filter mo.
    Quote Originally Posted by zix888 View Post
    iba ka talaga sir sir...nag usap na kau ng tito ko..??
    Sep 2013
    ok sir,yan ang next in line.
    Mar 2005
    Ngayon ko lang napansin yung fuse box sa engine compartment kulang ng 15A fuse dun sa number 16 fuel pump slot. Sadya bang wala talaga nakalagay dun? Glx a/t 2013 model yung sakin. Pa chk na lng mga bro yung sa inyo. Thanks!
    Feb 2013
    Mga Gurus, pls confirm if below scenario #3 w/ regards to "Oil Pressure Indicator" is normal or do I have to check it sa CASA, my ride is GLS-V 2013. TIA.
    1. Turn ignition key sa ON and wait for Pre-Heat indicator to OFF
    2. After engine Start, all indicator will Turn OFF, including "Oil Pressure Indicator"
    ** 3. After Oil Pressure Indicator light OFF, it will light ON again for less than 1 second then turns OFF
    4. Oil Pressure Indicator remains OFF while driving (I know this is Normal)
    Jan 2012
    Quote Originally Posted by kiros0110 View Post
    Don't ignore it. An oil pressure warning light (or low gauge reading) means one of two things: either your engine has dangerously low oil pressure (for a variety of reasons which we'll get to in a minute), or the oil pressure sending unit that triggers the warning light (or operates your gauge) has failed.
    Sep 2013
    Hello fellow montero sport owners, i've been lurking around and finally got our 2014 white GLX non-vgt, very satisfied w/ the power.
    Sir Zix i'm interested in the cabin air filter and KNN, pls. send PM.
    To God be all the Glory!
    Sep 2013
    Kindly advice on where to buy these and how much? for GLX 2014
    1. OEM parking/reverse sensor (avt is the oem brand ? any recommended brand?)
    2. OEM rear camera (avt is the oem brand ? any recommended brand?)
    3. HID for low beam
    TIA
    Feb 2007
    Quote Originally Posted by JOHN3:16 View Post
    3. HID for low beam
    TIA
    Here are my suggestions sir:
    1. Try inquiring from winterpine how much is their OEM reverse sensor. They are the distributor sa casa also.
    2. There are a lot of reverse camera(OEM type) sa sulit ranging from 1k to 2k pesos. If you are interested, i have the full glass type(below), pm me if interested.
    3. I would suggest go for retrofit. Check out hidretrofit.net by garyq. Sulit ang reviews sa kanya..
    Sent from my Nokia5110 using Tapatalk Pro
    Jun 2012
    Hi sir prince how much po ung reverse cam?
    but my problem eh meron na ako gusto ko sana palitan pano matakpan ung butas neto?
    Sep 2013
    Thank you so much sir prince for that helpful info.
    God bless.
    Feb 2007
    Sir ako din ha.. ;)
    Quote Originally Posted by jalen View Post
    yes bro, okay na. thanks
    Feb 2013
    Quote Originally Posted by Seeyah14 View Post
    Right after scenario 3 and while driving naka OFF naman ung indicator, every engine start lang nangyayari. Pero mukang nakita ko na yung fault ko kaya nangyayari yun. Kanina I tried to start the engine 2 secs after nag OFF ung pre-heat indicator then hindi nangyari yung 3rd scenario na sinasabi ko. Mukang lately ata medyo mabilis ako mag click ng start right after magOFF ung pre-heat indicator, mga 0.5sec after preheat OFF iniistart ko na agad yung engine, hehe. Nakasulat kasi sa manual na atleast before 5secs maistart na yung engine right after preheat indicator turns OFF.
    Sep 2011
    scenario #3 never happens to me, even after starting the engine immediately after the preheat indicator disappears. Tama si seeyah pacheck mo sir
    Mar 2012
    Just tailed a white trailblazer ltz. Observed the same black smoke during hard acceleration. Have seen forts and innovas doing the same. Sorry for bringing it up often, the montero is our first diesel and just beginning to accept its difference from petrols.
    pm sent sir, thanks
    pm sent sir, thanks
    sir Zix here also is interested with the KNN and OCC
2013 Mitsubishi Montero Sport owners
