Page 73 of 129 FirstFirst ... 236369707172737475767783123 ... LastLast
Results 1,441 to 1,460 of 3938
    Jul 2005
    How do you tell kung original yung gps sd card? Nakabili ako and accdg to the seller galing sa casa yung card. Sandisk card lang ba talaga or may label ng inav or Mitsubishi?
    Sent from my GT-I9100 using Tapatalk
    Aug 2010
    Quote Originally Posted by garci View Post
    You know, as long as it's authentic and your reader/GPS can read it, then any brand of SD card works. Kahit SanDisk pa yan, Kingston, or a re-branded Mitsubishi SD card.
    However, KNOWING if it's authentic from a fake is much harder. Transfer speeds is one.. but physically telling them apart? Konting malabo yun.
    Jul 2005
    Quote Originally Posted by jhnkvn View Post
    So does it mean the sd card na galing sa casa SanDisk lang talaga ang label?
    kahit anong label walang kaso, important thing is working properly yung navi mo
    Jul 2005
    Quote Originally Posted by zix888 View Post
    Thanks. Kailangan ma-install ko na agad.
    Apr 2013
    simple lang naman para malaman kung orig yung sd card ng navi na nabili mo sir. as long as once nag function yung navi mo hindi distorted ang map orig yan. pag fake or duplicated distorted yung map nalalabas sa navi mo.
    Jul 2005
    Quote Originally Posted by Bengbeng View Post
    Ugh... Looks like I got a copied one. The navi worked pero distorted nga ang map. Hindi kaya ito compatibility issue between the HU of the GLX and the GLS-V? Tiningnan ko kasi update ng iNav and there is a separate download for 2012 or below and 2013 na AVT. Ang the mid display ng GLX ko looks like it's 2012 since 8 buttons lang.
    The guy looked legit naman since he was driving a brand new Monty also and he swears he got this from Mitsubishi for his other unit na sa province daw gagamitin kaya binenta ang SD. The guy is also responding to my texts.
    Apr 2013
    yung unit ko is 2013 sir. ginamit kong update sa 2.4 noon oem ng 2010-2012 dahil wala pa sa inav.ph yung oem 2013 noon. sir ok naman sakin hindi nag distort yung map sir. tpos ngyon inupdate ko na using oem 2013 sa 2.5 ok naman din result sir hindi distorted map.
    Aug 2003
    Sirs, it is the combination of the oily blow-by vapour from the crankcase plus the exhaust soot from the EGR that forms an asphalt like layer on the intake manifold that over time leads to poor performance.
    Wala naman worries with a stock engine but you should be prepared to spend money and time for cleaning of the parts of the engine involved to maintain itin tiptop shape. It is part of PMS and will be offered by your SA at certain mileages.
    You can also opt to subtract one from the equation, like if you fit an Oil Catch Can, it will filter out a significant amount oil from the air intake charge. Then the soot recirculated is much drier and sticks less to the walls of the intake manifold. This will probably double the time it will take the manifold to clog. This should not cause any warranty issues kasi as it says, it just catches oil. Pero sometimes the casa technicians don't know what it is for and may think it is a performance mod, hence potentially voiding your warranty.
    Another part of the equation is the soot from the EGR system which can be blocked or restricted by inserting a plate in the pipeline. This is technically not legal because the EGR system was designed because of emissions requirements. But all over the world it is being done because of the carbon deposit problems and it compromises engine longetivity. Blanking the EGR will lead to a lot cleaner engine and less maintenance. There are a lot of styles to do this, but essentially you just need to stop the flow. This can be done discreetly without the casa ever knowing. Kaya pwede kahit under warranty. The earlier the better actually.
    For more info, google niyo sirs. The wikipedia result is actually a good read already.
    Dec 2008
    Quote Originally Posted by ek2jayvee View Post
    Adding info about EGR
    In diesel engines[edit source | editbeta]
    By feeding the lower oxygen exhaust gas into the intake, diesel EGR systems lower combustion temperature, reducing emissions of NOx. This makes combustion less efficient, compromising economy and power. The normally "dry" intake system of a diesel engine is now subject to fouling from soot, unburned fuel and oil in the EGR bleed, which has little effect on airflow, however, when combined with oil vapour from a PCV system, can cause buildup of sticky tar in the intake manifold and valves. It can also cause problems with components such as swirl flaps, where fitted. Diesel EGR also increases soot production, though this was masked in the US by the simultaneous introduction of diesel particulate filters.[6] EGR systems can also add abrasive contaminants and increase engine oil acidity, which in turn can reduce engine longevity.[7]
    Though engine manufacturers have refused to release details of the effect of EGR on fuel economy, the EPA regulations of 2002 that led to the introduction of cooled EGR were associated with a 3% drop in engine efficiency, bucking a trend of a .5% a year increase
    Jul 2013
    Since walang gnitong usapan (EGR BLANKING) sa forum namin sa strada, allow me to post it here.. mine blanked for about 1k kilometrs already, no issues of CEL.. the performance is very good!
    Jul 2012
    Mga sirs, questions lang:
    1. San po okay magpagawa/magpahalo ng touch-up paint (Quartz Brown) around QC-Trinoma area? May mga tama kasi yung edges ng door pag may mga hindi maiingat magbukas at tatama sa pader na semento.
    2. San po okay magpa-paint nung plastic rear bumper para maging kamukha niya yung nasa harapan (from black to i think, silver)
    TIA.
    Apr 2013
    Quote Originally Posted by jc16 View Post
    TIA.
    tanong mo muna sa casa yung color number ng unit mo sir. tapos dahilin mo sa ace or sa wilcon para timplahin dun.
    ok gumawa sa may autoworks sir along congressional ave.
    Jun 2008
    The code for the "Quartz Brown Metallic" is C06...remember there are different types of "metallic", you need the very "fine" or smallest granules. I had mine already re-touched due to scratches...
    Jul 2012
    Thanks sir. I'll confirm the color number. Sana pwede ipatimpla kahit konti lang.
    Salamat sa reply!
    Quote Originally Posted by dj ian View Post
    sir im also interested on egr blanking, picture naman sir on how to do it. thanks
    Saan bro may egr blanking, & how much?
    Thanks.
    Apr 2013
    Quote Originally Posted by Noel Salisipan View Post
    Thanks.
    try mo sa jc garage sir. meron siyang blankplates binebenta
    Beng, pwede na ring mahingi yung detail ng shop. Address & contact number kung meron?
    Thanks.
    Jul 2013
    Thanks.
    Pinagawa ko lang po sa machine shop. Inalis ko ung egr pipe tapos knuha ko ung pinakagasket na stainless steel then pinakorte ko din syang gnun at walang butas para walang dadaanan yung soot. Inilagay ko sya dun sa pipe na b4 egr cooler sa may exhaust manifold. I decided to do this nung i tried to clean my intake manifold myself.
2013 Mitsubishi Montero Sport owners
