Page 42 of 197 FirstFirst ... 323839404142434445465292142 ... LastLast
Results 821 to 840 of 3938
    Mar 2013
    #821
    I have the same problem with the key in my vehicle which I just received last saturday or five days ago. I have to jiggle it back and forth. Putting singer oil doesn't really help. Defective talaga.
    Feb 2013
    #822
    Quote Originally Posted by marvmcsbest View Post
    Yup still 2.3 yong ms 2013, kaya ang ginamit ko ay yong ms 2010-2012...so far ok naman, wala naman ako na encounter na problem! Unit ko pala glx non-vgt 2013..
    Thanks sir Marv for the feedback, same lang ba yung MIS ng GLX sa GLS-v model?
    Has anyone tried the same for their GLS-v?
    Mar 2005
    #823
    Quote Originally Posted by Twomix View Post
    envy-R, Twomix, ganyan din unit ko when I got it Jan 31. Took them 4 days bago na solved yung problem, they replaced the rubber doon sa may susian na attached sa cable and solenoid 4 times. Sa Casa when they replaced the rubber, gagana siya pero pag tinakbo mo na then patayin mo makina di na mabubunot susi. They even consulted the planta daw and got the right rubber pero to no avail . Finally they decided to change the cable (not sure kung assy yun with solenoid) and that solved it. Ibalik mo sa casa, they should know what to do.
    Apr 2013
    #824
    Guys wla na bang air filter ang montero sports 2013? Nag pa PMS ako kanina sinabi ko palalagyan ko ng cabin filter yung skin sabi ng SA w
    A raw lagyanqn ng cabin filter ung montero. I even ask dm valle verde wala rin daw. Meron ba tlgang lagayan ng filter ang aircon natin?
    #825
    Quote Originally Posted by Bengbeng View Post
    Check mo na lang. Sa ilalim ng drawer yun. May bubuksan.
    Apr 2013
    #826
    Cge tom morning ko i check. Medyo pagod ako ngyon lang ako natapos sa pms. 6:30am sa citimotors alabang ako ung pang una. Tpos natapos ako mga 1:30 pm na napakatagal ng service nila ska maraming kalukohan dun. Avoid nyo nalang mga mitshubishi owners.
    Mar 2012
    #827
    if you will backread bro or sa ibang thread ditto sinasabi na may ikacut para dun sa butas kung saan ilalagay yung filter, then manually din ata iaattach/secure
    Apr 2013
    #828
    Ah ok. So wala tlaga. Ngyon lng ako nakakitang aircon system na d nilagyan ng filter. Malakihang gastos nanaman yan sating mga owners. Hayz!
    #829
    1500 lang naman yung washable na torque aircon filter.
    Mar 2005
    #830
    I also have bad experience with Citimotos Makati back in my Lancer pizza days. So ibig sabhin di pa rin sila nagbabago.
    Dec 2011
    #831
    Quote Originally Posted by beeper0358 View Post
    Ito yata yung cable na nag-eensure na di mo mabubunot ang susi kapag hindi nakaset sa park yung kambyo.
    #832
    Guys, tanong ko lang kung natatanggal (via screw) ba yung shift knob ng MT natin? Hindi kasi ergonomic sa quick shifting yung stock knob design. papalitan ko sana nung Ralliart na stainless.
    Aug 2008
    #833
    Quote Originally Posted by ash0279 View Post
    Ikot mo lang sir counterclockwise yung knob. Lahat ng shift knob ganun. Me thread. Yung akin nung nagpagawa ako seat cover sa seat mate pinalagyan ko din ng leather yung shift knob. Pangit nung knob ng pang glx manual
    Jan 2013
    #834
    Solved na sa kin mga bossing. Wala namang bayad. Hassle lang ang pila sa CTMotors Mkti albeit warranty issues are prioritized pag naipasok na? Very accommodating yung gumagawa ng warranty issue, Manong Pits yun assigned SA sa akin sabi nya Engineer daw. I took him less than 10mins to replace the rubber damper. After magawa hiniritan ko si Manong kung may solution na yun MMMIS and I was referred to Julius sa accessories walang tanong pinalitan ang HU ko. So far di pa nag hang ulet. So sa madaling sabi, naayos two problems ko in 2 hrs time. I currently am dowloading the map update--ver2.4 sana gumana.
    Jan 2013
    #835
    TwoMix, ganyan din ako nagsimula ON then shift to D then back to P ok na and i thought it was normal. Tapos lumala. Nun makita kung maraming rubber na allocated sa MotorPlaza i assume that the case is prevalent. i-tag nilang CAPTURED yung unit sa list nila pag napalitan na ng rubber, i dont know bakit yun ang term na ginagamit.
    #836
    Guys, kanina ko lang nadiscover, normal ba na hindi mag-fully open yung power windows (both sides) sa rear passenger? sort of 3/4 opening lang kahit todo bukas sa switch.
    Jul 2010
    #837
    ganyan din yung rear windows ko
    Nov 2012
    #838
    Ganyand din sa strada. I think it has something to do with the bottom curve of the window. Yan na ying lowest pt para di pasukin ng tubig. But I may be wrong.
    Sent from my GT-S7562 using Tapatalk 2
    Dec 2011
    #839
    Normal lang iyan, kahit mga kotse di rin sagad baba ng windows sa likod.
    #840
    Thanks for the replies re rear window not being fully opened. At least mapapanatag na ako ngayon. (Nasanay lang kasi ako sa CRV Gen 1 ko dati)
2013 Mitsubishi Montero Sport owners
