long time no post..
Dinala ko si Monty (GLS-V) nung Sat sa casa to check din if kasama sa recall. I didnt have any appointments pero chineck naman nila sa list nila using the VIN and sa lahat ng mga gagawin, hindi naman nakalist yung VIN ko.. I think safe na ata itong unit namin even though purchased 2012 pero 2013 model.
Not sure kung 2011 and 2012 models ata ang rinerequire?
Guys nasabit yung montero ko at nagkaron ng deep scratch, parang may bangas yung affected area sa bumber sa likod, san po ba makakamura if ever need i-repaint? Should i use my insurance? Help naman.
Yes you can use your insurance but you have your participation (deductible) parang quits lang rin ang kwentada nyan if magpapa repaint ka outside casa less hassle for the docs needed.
any idea kung paano malalagyan ng indicator ang instrument panel ng a/t monty? D makita pag d naka on ang lights ng instrument panel ang gear ng a/t. does installing a cabin filter voids the warranty of a new monty?
Pwede yan sir lagyan ng lighting you can ask more info to DIY guro sir zixx, marami na naglagay ng cabin filter so far wala naman issue sa warranty.
where can i locate the said person? i got this unit last march. how much does this cabin filter cost?
*ueb339
sir pacheck na lang po inbox ninyo, may PM po ako sa inyo. thanks
boss zixx, thank you for a short but nice and very informative discussion with you last Sunday morning (iba ka talaga pagdating sa mga DIY.... ) and hoping to meet you again by end of September para dun sa ini-reserved mong DRL module sa akin....(may basbas/approval na ng account manager... hahaha)
Mga sir. Nakaencounter na ba kayo ng problem sa monty nyo na parang paling yung monty nyo. I mean pag nakaupo ka sa driver seat eh parang mas mababa yung left side which is the driver seat kesa sa right side which is the passenger seat? Actually my steering wheels din parang paling. kasi pag iniistraight ko yung steering wheel eh lumiliko ako pakaliwa
tingin nyo may problema kaya to sa shock?
were talking on the same language pala sir. hehehe. (sensya na po mga ka-tsikot - OT). see you soon sir.
Just to share the improvement made by K & N to my ride, you can see talaga the difference on accelaration between stock and the less restrictive air filter.Thanks sir zix for sharing the additional mods.
good morning tikoteers! o.t. lang po
experience last friday na hindi gumana ung auto shifting ko nasa 2500 rpm na and yaw pa rin pumasok sa second gear so i tried manual gumagana siya but when i revert back to auto ayaw nya mag auto shift.tapos maya maya nag appear na check engine.scan it and yields report of P1901-POWERTRAIN,for mitsu it says A/T fail (engine timeout).and for mazda it says torque converter clutch circuit intermittent.however when im about to drive again it shifted back to normal again in auto mode but still check engine still there tried to reset it about 2 times with engine running and with engine shut off but key in ON position.but to no avail.and then i finally get it a rest.after that it reverts back to normal again.by the way im using torque apps.with bluetooth obd2 scanner.
