Thanks po... akala ko kasi parallel sya icoconnect... pero di ko muna tinuloy...
Connecting it in parallel with the LED bulb will effectively lower the R - even lower than the current LED bulb resistance.
Bro - you need to increase the resistance as seen by the circuit and the capacitor,- and so you place it in series with the LED bulb/light. Just cut the wire just before the socket and connect it; Works on either of the [2] lines
Have not really tried it,- just theory based on this...
T=RxC...
Make sure that the aux cable you are using is AV. Try this. TV Plus to Car Monitor AUX Socket Direct Cable GZ-8 5 3.5mm AV Baby to Baby Plug 1.5meters | Lazada PH
Sent from my SM-G975F using Tapatalk
I have an question/issue with my 2013 montero. Specifically the power side mirrors… when I activate my power side mirrors the passenger’s side mirror folds open to its correct position while my driver’s side mirror folds open too much, it folds open to about 180 degrees but when I press the button to fold the side mirrors back in, both side mirrors fold in just fine only when they fold out the driver’s side folds out to 180 degrees while the passenger side mirror folds out just fine. Is there a way synchronized the side mirrors without having to open up the driver side mirror? Thank you.
Hi Incy, nabali na yung stopper niyan kaya open wide na siya. Dati, nangyari na sa Montero namin yan. Pansamantala, hinahawakan lang namin kapag nag-open para tumigil sa desired angle hanggang pinalitan na rin namin ng replacement side mirror. We asked casa about repair, palit buo rin ang suggestion kaya naghanap na lang ng cheaper alternative online
Sent from my Xcover Pro using Tsikot Forums mobile app
mapapagana kaya ung rear fog indicator sa dashboard? been thinking of using red films on my left side backup lights tapos bili ako ng oem switch para maging rear foglamp
