Sir ice15 nakapagpalit na ba kayo ng third seats para maging 7 seater? If not yet I know the supplier of the OEM seats that supply them to Mitsu... Pero you'll need to replace quarter panel trims kasi un 9 seaters have 5 holes on the trim panels at pag nagpalit kayo 7 seater na meron 3 holes lang sa panel.
wala pa po bang bagonmg facelifted model ang adventure for the year 2013 or 2014?
ano b yung difference po ng 2012 sa 2013 model? we're planning of getting one..not decided yet if its a 2012 or 2013 model? and if glx or gls variant?
ano po ba difference between the 2 variants?
any help and advice po are welcome>>![]()
same din before sakin bro, kala ko normal sa gas yun kase dati de diesel ako kaya diko pinapansin pero katagalan lalong lumalakas. kaya nung pina tsek ko sa mekaniko ko ang problema e yung transmission, clutch cylinder assembly. kaya nung na repair naging smooth na yung pag shift nya. para sigurado pa tsek mona din sa magaling mong mekaniko para makasigurado ka. lalo pa at necessity ang sasakyan ngayon.
Mag tanong lang po sa mga adventure owner. Magkano po pa every 5K and 10K PMS nyo? Sa akin kasi P4500+ for 5K PMS and P8000 for the 10K PMS, fully sythetic oil gamit ko.
fully synthetic oil for 4d56 is just a waste of money.. read your manual for the proper oil rating you need..
ako 2k lang per pms hehe ako lang gumagawa eh... ginagamitan ko pa ng flushing oil using petron HD kaya up to now pag nag change oil ako malinaw pa rin ang oil after 1 week of use..
Sirs, magtatanong lang po...yung spare na rim ng adventure gls super sport the same lang ba sila sa lahat ng rims? thanks.. newbie here![]()
most tires and rims/mags of a particular car are identical to each other, off the factory.
some entities choose to change them, probably to enhance profit or beauty.
and some more modern cars have a much smaller spare tire, so as not to occupy much space in the trunk. these strictly emergency spare tires are not designed to be used on the road for a long period of time, but only to enable the driver to get to the flat tire shop..
Pki-check mo sa front seat passenger side, tingnan mo ang ilalim ng upuan. Makikita mo yung jack na nka-secure. Pki-secure mo ang lock screw at rubber band ng mabuti. Minsan ito ang nadiscover kong rattle sound. I thought na may vibration somewhere but wala naman pala kundi nag-loose lang ang lock screw.
I hope ito nga ang dahilan (like mine) but if not and otherwise, then its something else... One thing is for sure, sa advie ko, wala akong naririnig na rattle sound of anything (except nung nag loose nga ang jack).
Thanks.
Sir ondoy2008 saan branch ng el dorado mo pinagawa? Ganun din problema ng advie ko. Thanks.
Regarding TOK Sound. Steering coupling nga yan. Pag remedyo, linalagyan lang nila ng plastic. Para hindi tumunog.
But the best is to have it replaced. If your adventure is still under the 3year warranty, then replacing the steering coupling under warranty is free. As in Free, you just have to drive in and ask the service advisor to have your unit check and replace if needed.
But just in case the Adventure is not anymore under warranty, then you might as well replace the steering coupling.
I got mine replaced by a friend in Manila. However, by appointment lang sya. The Mechanic is very well experienced. Look for Mang Endoy. I have mine replaced with a new steering coupling, damage is 7k inclusive of labor.
Will check with him if its ok to post his number here.
