Page 96 of 212 FirstFirst ... 46869293949596979899100106146196 ... LastLast
Results 1,901 to 1,920 of 6900
    Apr 2008
    Sa wakas dumating na din plate number ko after almost 6 months via air21. Ngayon may color coding na ako waaah.
    Mar 2012
    Quote Originally Posted by dandang View Post
    medyo matagal din sir ah... yun sa amin 1 month after nabili
    Sep 2004
    Anong klaseng amoy sir meron kapag refrigerant leak? Maasim? Mapanghe? Amoy usok?
    May 2012
    sa monty ng ate ganyan din noong una ang amoy sapatos tapos minsan naman amoy hindi maintidihan....ginawa ko lang everynight lagyan ko uling sa harap gitna at hulihan nawala man
    basta ako i kill the a/c but leave the fan on a few minutes before arriving at my destination to avoid moisture accumulating in the system.
    salamt sa info sir hindi ko na isip ah
    Jul 2012
    21 days from the release of my mountain warrior, I got my plate the same day with 1000 PMS (1089km actual).
    bilis ah! sakin mag 2 months na wala pa din ang special plates ko. may mga nakikita akong 2013 fortuner may regular plates na agad.
    Sep 2006
    Quote Originally Posted by mangkas1178 View Post
    sang dealer kau sir & which LTO kinuha plate nyo? astig buti ka pa sobrang bilis.
    Jul 2012
    Quote Originally Posted by maChx View Post
    Sir Jabez MMC, Dasma and LTO agency Kawit.
    just got my gls v montero last month. nagtataka lang po ako na city driving ko lumalalabas eh 5.5km/l to 7.9km/l lang po. ganun ba po talaga?
    Aug 2012
    hi po sa inyo. finally got my montero sport na dapat glx pero na upgarde sa glsv dahil napakatagal dumating ng unit. anyway for me mukang napaganda pa nung nag upgrade ako. dami ko na agad natutunan d2 b4 ko pa nakuha ms ko.
    tanung ko lang kung magkanu inabot ng first 1000km pms nyo and kung saan maganda magpa check. salmat po. more power
    Aug 2012
    Aug 2012
    Quote Originally Posted by treadstone1223 View Post
    base po ba yan sa multi info display? observation ko po pag malayo byahe tumataas yan tapos pag medyo malapitan lang and city driving mababa po reading nya
    Sep 2012
    fellow monty owners, mine is ms non-vgt, ask ko lang kung panomaaccess yung card slot ng hu? subukan ko sana yung steps sa adventure thread regarding sa unlocking ng navigation, TIA
    Sent from my XT910 using Tapatalk 2
    Mar 2012
    Quote Originally Posted by puroiskii View Post
    sir, ma-access nyo sa kapag na-open nyo yun cover panel nun HU nyo. my mga previous post dito po how open that. yun sa akin sir is on the left top ng HU yun SD card slot. I think my nagpost dito ng link sa you tube how to open the HU cover.
    Sep 2012
    salamat sir, backread muna ako
    eto na sir yung video
    http://www.youtube.com/watch?v=GKgdGP2Mfus
    Sep 2012
    Quote Originally Posted by zix888 View Post
    Montero sport gtv - YouTube
    maraming salamat sir, nabuksan ko na, kalikot mode muna ako.. available ba sa mga pc store ang SD card extension? quezon province kasi ako eh, TIA
    Jan 2008
    Calling Montero sport Gurus (Sir Six and sir prince...etc) I bought a reverse cam from the net USd 14.0 and wanted a DIY installation. My problem now is how to route the wires coming from rear door passing the rubber grommet and into the roof. Do you have some info about this sirs, the instruction from the reverse cam only says about the connection of wires. BTW, I have a GLS-V. TIA
    Quote Originally Posted by Hornyspear1 View Post
    one way! stretch your fingers first before going thru the process of routing the wires there sa rubber tubings, hehe.
    Jan 2008
    Work in Progress...Passing the yellow RCA on the grommet was done. Yellow RCA is now on the roof upholstery and thinking where to route next.
    a. Do I need to pull down the roof upholstery and lay the yellow RCA wire through the drivers pillar?
    b. Lay the wire going to the side near the jack well then route it under floor mat going up to the front and into the back of monitor.
    What's the best or correct way? TIA
2012 Montero Sport Owners
