Page 89 of 212 FirstFirst ... 397985868788899091929399139189 ... LastLast
Results 1,761 to 1,780 of 6900
    Quote Originally Posted by RKL View Post
    should i change my head unit just to get those features?
    may mga accesories lang na bibilhin to get those features, same HU
    Aug 2012
    Quote Originally Posted by zix888 View Post
    Thanks! any recommendations? iba iba ang sagot sa akin ng Sales Agent at ng Winterpine kung kausap ko sila eh.
    afaik, all you need is the RV meter and the sd card, its almost like the glsv set up already( w/o steering audio controls)
    Jul 2012
    "clear", as in
    As in cellphone quality. Both in/out going. Pero mas okay yata yang sa inyo Sir. Baka "land line" quality.
    Quote Originally Posted by Jesto View Post
    my HU was replaced by Winterpine. GPS did not function after 1 week pa lang.
    They are located in front of UERM along Aurora BLvd Look for the big # 40. Better go early. dami laging nagpapagawa. sandali lang palitan
    Sir parang 41 yata yun.
    Nov 2011
    Saan po nakakabili nung "V" sa baba ng gls? 2011 model kasi sakin kumukupas na..
    Jul 2012
    Quote Originally Posted by clairenceh View Post
    Sa casa po meronyan. Call your SA.
    Sep 2012
    share ko lang montero sport 2012 test drive sa vietnam
    [ame=http://www.youtube.com/watch?v=QBJ6MVvUd44&feature=fvwrel]Test drive Pajero Sport 2012 with H.Masuoka in Hanoi - Vietnam - YouTube[/ame]
    Jul 2003
    yun Gls-v pwde ba pa fit Oem hid fm GTV?
    kahit yun buong headlight assembly, plug and play?
    or get a 2nd set GLS-v headlights then pa gary's retrofit
    this early i want to invest on the lights kaya baka hindi ako masaya pag pa install lang ng Hid kit sa gls-v.
    Yun 2008 camry palang ang na drive ko na HID, wala ng iba. I currently use Phillips Vision plus and Osram nightbreaker (tumagal buhay kasi kabit ko pag out of town lang ako).
    thanks
    Sep 2012
    hingi ka sir sa dealer mo, libre lang yan..
    Aug 2006
    Quote Originally Posted by wsa 400 View Post
    GLS V and GTV owners
    Please advise if the HU audio adjustments in the unit feature equalizer or DSP or just plain bass and treble. Will consider this in upgrading the AV system of the GTV when it is delivered. Thanks in advance
    Will probably crossover to the MSCP group from the Fortuner club :>)
    No equalizer
    Jul 2012
    You can try mr zix's guide on removing HU cover. Look on youtube.
    Jun 2012
    Quote Originally Posted by superblitz View Post
    Thanks sir, I saw the video pero ung rattle ko kasi is dun sa cover dun sa may radio part.
    Dec 2011
    good day mga sir..pa help naman mga fellow monty owners mangayri kc kahapon ng hapon nung start nila si monty ay di n gumana yong monitor display sana sa pag lagay pa lang ng key sa acc dapat mag on na yon..pero wala at pati yong HU ko di n rin nag o-on...is it fuse lang kaya ang problema..di ko kasi totally macheck kc andito ako sa barko si kumander lang andun..may naka experienced n po b s inyo ng ganito...san po b banda ang fuse box? hope to hear from you mga sir...TIA
    Sep 2012
    gud pm mga sir, newbie po ako d2, madadagdagan po ba ang top speed ng gls v 4x2 stock sa rated H na gulong, S po kc ang stock, maraming salamat po
    Sep 2012
    Quote Originally Posted by rap2_tan View Post
    Madalas kasi mangayari. Parang kanina on our way to antipolo. Malaking tulong kasi yung voice instruction. By 5k pms siguro pacheck ko na.
    Quote Originally Posted by spark_29ers View Post
    sir nangyayari talaga minsan, blank siya, pero after turning off and on again, okay na. kaya nga naglagay ako ng on/off switch ng MIS
    ( http://www.youtube.com/watch?v=MZZjTAZIBC4 )para if you are on the go tapos hindi nagstart up ng diretso, hindi na kelangan huminto para switch on and off yung ignition para marestart yung MIS.
    btw eto yung fuse niyan
    Dec 2011
    ( montero sport gtv optitron combi-meter - YouTube )para if you are on the go tapos hindi nagstart up ng diretso, hindi na kelangan huminto para switch on and off yung ignition para marestart yung MIS.
    maraming salamat Sir Six888 talagang maasahan ka s mga ganitong mga issue at problema.thanks s mabilis n reply.
    By the way Sir ilang beses n rin silang nag try start ang makina pero wala tlagang power yong display pati Sir yong stereo di rin nag pa power eh..
    Try ko pa check s brother ko ung Fuse at Sir saan po ba banda itong fuse box na ito?nasa loob po b ito ng cabin or nasa may engine bay? madali lang po ba sya ma-access..pasensya na po at di p ako masyadong familiar sa mga part/location sa monty natin...first car ko lang..marami pong salamat uli...
    Aug 2012
    Hi guys, does anyone know the reset maintenance code for gls-v, got it late March at citimotors makati. 6923 didn't work...
    Apr 2011
    Hi G323,
    Did you successfully reset your PMS warning sa HU? Ano po gamit nyong PIN to reset? Anybody knows?
    Thanks in advance.
    Quote Originally Posted by G323 View Post
    Sep 2012
    Quote Originally Posted by dhinster View Post
    Hi G323,
    Thanks in advance.
    same here 6923, invalid code sa HU ng aug 2k12 gls v
2012 Montero Sport Owners
