Page 86 of 212 FirstFirst ... 367682838485868788899096136186 ... LastLast
Results 1,701 to 1,720 of 6900
    Aug 2006
    naku delikado nga kung magregister ang caller sa monitor hehehe giyera patane sa loob ng sasakyan
    Ala e ang mga tsikoteer pala e chickskoteer din ...
    Aug 2006
    Quote Originally Posted by kckm View Post
    Sa kid audio sir sa binan... Mahirap lang don pag madami ka nakikita gusto mo pakabit lahat... Dapat tint lang sana pagawa ko don for 5k budget. I ended up spending 24k ...
    Hehehe, same case here ... Kumpleto kasi doon ...
    Kaya better bring only enough cash for what you really need ...
    Apr 2008
    Quote Originally Posted by macstar1 View Post
    Where is kid audio in binan? Is it along national highway? Or papasok pa sa bayan?
    along the hiway lang bago mag pavillion mall pag galing ka sta. rosa. right side.
    Aug 2004
    good day guys.. i think may problema ang alarm ko.. unit is a month old gls-v a/t with 500+ kms (di masyado gamit) so mga 2-3 weeks pa bago madala sa casa for 1k pms;
    a week ago, pag-off ko ng engine sabay bukas naman ng kasama namin ng trunk door. what happened was tumunog ang alarm nya. do ko alam ang cause, baka kako nataon lang. 2 days after while parked sa garahe, bigla tumunog ng 4 chirping sounds, continuous sya with about a 3-second interval. so i turned off the alarm pero pag inilock ko ulit tunog na naman sya. then kahapon nakapark lang sa garahe ulit, bigla na lang nag alarm. after that everytime i-lock ko, naglock na sya with 1 chirp then after 3 seconds may kasunod na 4 chirps.. upon reading the manual, it says "if the system detected a bad sensor or an open zone, the system will chirp 4 additional times" .
    anybody experienced this?
    TIA
    Dec 2008
    Quote Originally Posted by Elroi View Post
    TIA
    same problem, replaced shock sensor under warranty. looks like common problem with montero mine is just 2 wks old.
    nagalit nga kapitbahay ko madaling araw alarm ng alarm
    Aug 2004
    Maybe you can check if all doors are properly closed kahit walang door warning sa instrument panel. Kung ganun pa din dalhin nyo na po sa casa or sa winterpine(aurora).
    Quote Originally Posted by EuroFD View Post
    *Elroi: I recently experienced alarm problems like yours. I brought my Monty to Winterpine Araneta Avenue for an inspection. Upon checking, they replaced my alarm shock sensor under warranty. Now the alarm is back to normal. HTH
    Quote Originally Posted by reloaded_acer View Post
    thanks a lot guys.. will call the casa tomorrow to report the problem. gaano ba katagal palitan yung sensor, meron ba sila agad stock ng parts o iorder pa? isasabay ko na lang siguro sa 1K pms pag matagal.
    May 2012
    My alarm for the GLX model also had problems. Nawawala yung siren, minsan meron. Nag lolock, unlock siya, yun nga lang walang audible warning. Last week walang chirping sound, ngayon naman meron na naman. Might have it checked sa CASAa to be sure.
    Apr 2011
    Thanks for this info, just encounter this same problem on alarm. Pachk ko nga din sa Winterpine.
    Feb 2007
    Aug 2006
    Just had my MS GLX AT serviced at Diamond Motors Valle Verde (1000 KM)
    5,300 pesos, fully synthetic. . .
    I understand na bulok ang oil na gamit nila pero pagtyagaan ko muna at least until 10K PMS ... Until Im almost sure na walang lalabas na factory defect yung MS ko
    Feb 2011
    * macstar1 ilang ltr ng oil na charge sayo sir?
    Aug 2006
    Quote Originally Posted by braad View Post
    7 liters of turbo XP if im not mistaken ...
    So far, satisfied naman si Misis sa performance difference ...
    Jun 2007
    Jul 2012
    Mababait naman mga tao sa Winterpine at okay naman lounge nila.
    Aug 2006
    Quote Originally Posted by glaks View Post
    fellow non vgt owners.. success po finally working. I'm willing to share with you guys yung file just bring SD card with you and drop by sa place ko fairview pag weekends and jupiter st makati pag weekdays.
    (dont worry walang fee. hahaha) ayaw ko po e-post baka pag kakaitaan po ng iba.
    some pics
    Chief,
    Ok pa po ba yung offer nyong magpa kopya ng sdcard for MS?
    Dito lang ako sa Mandaluyong with office at Makati ...
    I can easily drop by at your place at Jupiter
    Thanks!
    I am in the final phase of trading in my Fortuner for a Montero Sport GTV and would like to know about some modifications. I live in Dasmarinas Cavite
    1. Turbo timer- is it recommended and will it void the warranty. Btw what is the best brand and how much
    2. TPMS: planning to get 20's installed. Will it still give the right tire pressure reading
    3. AV system: will upgrade by installing an amplifier, separates for the front and coax at the rear and powered sub. Does the installed av system have the RCA outputs. Also, does the installed av system have EQ settings or DSP? Do I have to install a DSP unit.
    Thank you in advance for the assistance of MS owner
    Quote Originally Posted by wsa 400 View Post
    1. i recommend volution TT, it is fully automatic. siya na magdecide whether it 30s, 1min, 2min ....... ang magiging cool down time mo depende sa pagkaka-use ng rig mo
    2. basta compatible ang mounting ng sensors
    , good to go ka na. kahit saan wheel set naman, same reading naman siya.
    this should be the mounting of your valve stem para pasok yung oem tpms sensor
    may mga wheels kasi na ganito ang mounting, hindi pwede yung sensor
    Quote Originally Posted by zix888 View Post
    Thank you for providing the valuable tips. Can't wait to get the unit released
    Feb 2012
    Naexperience nyo na ba sa gps na biglang nawawala yung voice instruction? Hassle kasi kailangan ko pang ireset ang unit.
2012 Montero Sport Owners
