Results 6,561 to 6,570 of 6900
- Sep 2015
- 20
July 11th, 2017 03:40 PM #6561Did not go to winterpine. Our of warranty and from Cavite pa ako
Sent from my SM-G900F using Tsikot Forums mobile app
July 25th, 2017 06:59 AM #6562
Ok ba to gamitin na gear oil? :
mag 1 iyong last gamit ko pang change kaso wala ako makita sa true value. Tsaka on sale din sila
when you look into the abyss, the abyss looks into you
- Nov 2014
- 91
July 25th, 2017 11:17 AM #6563
I suggest you stick with the recommended 75w85 GL-3. I tried using 80w90 GL-4 before, mahirap i-kambyo ng primera when cold, then mahirap din i-down shift from segunda to primera. Drained the oil after two days kasi matigas talaga and replaced it with 75w85 GL-3, ok na ulit. Malamang next question mo is san ko nabili?Banawe po, can't remember the shop, inisa isa ko kasi, halos naka-20 stores ako bago ako nakakuha.
July 25th, 2017 01:49 PM #6564
^ i meant for rear diff pwede ba siya bro? matic naman din kasi iyong rig namin
- Nov 2014
- 91
July 25th, 2017 05:54 PM #6565
July 25th, 2017 10:19 PM #6566
ah ok. so ito pala ang pwede bro
GL-5 8 W-9 - MITASU OIL CORPORATION, JAPAN
- 61
July 26th, 2017 09:37 AM #6567Baka may alam kayo na shop for stereo panel. I'm planning to upgrade my HU. Thanks..
- Jul 2016
- 939
July 26th, 2017 09:56 AM #6568If money is not an issue. Eto gamitin mo, may 75w-90 rin sila. 2400per liter at autoplus.
Motul - Products show
- Nov 2014
- 91
July 26th, 2017 03:15 PM #6570Buy 3 liters pero mga 2.5 to 2.6 liters lang mailalagay mo jan. Do not fill up to the lip like yung nakasanayan na pinapa-overflow sa filler, sobra po yun. Kapag abot na ng pinkie finger nyo from the hole yung level ok na, or you can use an allen wrench, kapag naabot na yung tip, ok na yun. HTH.
Mukhang exception ang VW case mo. Current daily pa din ang VW unit, at okay pa rin support sa...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
