Results 5,501 to 5,510 of 6900
May 15th, 2014 12:17 PM #5501
*the_mechanic & zix,
Yung abang na wire po ba sa console is pasok ang plug dito?
Thanks
Sent from my Nokia5110i-VgT using Tsikot Forums
Tsikot Member Rank 1
- Jul 2009
- 4,090
May 15th, 2014 12:28 PM #5502
May 16th, 2014 07:56 PM #5503
sir prince, parang hindi po. yun socket nun sa inyo is more on rectangular shape while yun plug sa akin is more on square ang shape. 2nd, yun plug sa akin ay may 5 holes (upper) and 2 holes (lower) and I think ka -partner (plug) po nun sa inyo should have pins (just my opinion).
- May 2014
- 1
May 17th, 2014 02:20 AM #5504Mga sir. Ask ko lang kung saan iniinsert yung sd card for navigation. Glx po yung unit ko. Thanks!
May 17th, 2014 09:16 AM #5505
May 18th, 2014 03:53 PM #5506
From previous page/s:
http://tsikot.com/forums/showpost.php?p=1992441
- Jun 2012
- 4,447
May 18th, 2014 07:42 PM #5507ask ko lang mga sir ilang litro ang idadagdag na langis sa top up? mag25k km na kasi. and ano pa ibang dapat gawin sa 25k km? thanks
May 18th, 2014 08:40 PM #5508
I suggest magdala ka lang mga half to 1 liter. depende kasi yan sa oil level mo, konti lang naman kapag kailangan i top-up, o minsan no need na. merong naka-post dito sa forum at mitsu website na periodic service menu ng gagawin sa minor at major pms. check the links
http://www.mitsubishi-cebu.com.ph/in...vice-menu.html
http://www.diamond-motor.com.ph/index.php/serviceLast edited by monty_GTV; May 18th, 2014 at 08:47 PM.
- May 2012
- 372
May 19th, 2014 01:45 AM #5509hi guys, noticed kanina when my dad started the engine for warm up then after like 3 to 5 mins, he turned on the A/C. usually from the outside i would hear a compressor click then a little idle up then the distinct buzz or humming note of the auxillary fan all together. And i would also hear this to other monteros parked with aircon on usually in parking areas when you walk pass them or a montero passing by you while walking in the parking lot.
a while ago its unusual, i heard the compressor click, the engine idled up but the "distinct buzz, sound or pitch" of the auxillary fan was not there. I checked the auxillary fan, its moving but i guess it wasn't fast enough. I also noticed that if the aircon is off, the auxillary fan still rotates like on a Number 1 speed (example 3 speed electric fan). when i turned the a/c on, the fan speed seems to be on the number 2 speed that it should be in number 3 (for me to hear the distinct sound / pitch of the aux fan). though the aircon is still cold.
Busted na ba yung auxillary fan mga sir? replacing time?
May 19th, 2014 07:52 AM #5510
Pag busted ang aux fan , it will lead to overheating of your radiator. Ilang mileage na monty niyo? Better to bring your unit sa casa to check your aux fan, radiator and aircon cooling system.
Posted via Tsikot Mobile App
Thread was made nung 2018 pa po sir.
