Wow, label po. Thanks. Ako try ko rin to.
Sent from my GT-I9100 using Tapatalk
My pulled out fuel filter on 20k pms with 20,349km serviced.
Sa latest gps update fm inav.ph, white na and daylight "theme". I like the icons of Pois and may pics at description na ilang esthablishments.
* sir mangkas, is it your fist time to replace your fuel filter element? lucky for you to reached 20k kms without getting CEL. others change their filters as early as 6k kms. I had mine replaced at 19k, 23k and 35k kms. all encountered CEL. almost at 50k kms now but still hanging on![]()
Sir monty scheduled replacement po yan and no CEL encountered. Try mo power booster on every tank fill up ng diesel, its a petromate product available at petron gas station cost P50 to P55 for a 125ml bottle.
Sa akin 13km to and fro magpakarga lang sa unioil.
Intercooler upgrade biggie size by master ZIX
Sent from my S3 using tapatalk 2
Mga peeps, may CEL indicator ba ang glx-V limited?
Sent from my GT-I9305 using Tsikot Forums mobile app
Patanong guys ano kaya problema nung montero namin, humina hatak. Tapos umilaw airbag. Tapos ayaw na gumana speedometer. Thanks
dun din ako nagtataka sir. iba ibang parte ng sasakyan. airbag, engine, speedometer. isip ko baka may ngatngat ng daga yung wire. sunday pa naman bukas. sarado casa
A possible cause: if you have regular high pressure underbody washing, the water jet could do this damage, particularly if at close range. I have a pressure washer at home and observe how much force can be generated by water alone, if there are sand and soil on the part, it acts like sandblasting.
Sent from my GT-I9505 using Tapatalk
Sir dct, any new electronic/lighting accessories installed? also might be possible from low battery voltage.
