Page 200 of 212 FirstFirst ... 100150190196197198199200201202203204210 ... LastLast
Results 3,981 to 4,000 of 6900
    Ito ang pinag replace ko na rubber dampers early this year. Definitely harder iyong replacement compared to the oem ones w/c seemed to have a spongy & flaky constitution
    so far never pa naman tumukod iyong sasakyan from the very start
    Apr 2012
    i think ganyan din nakakabit sa monty ko from bro zix. mas harder nga ang composition ng replacement rubber damper compared sa oem. malamang tumutukod din yung sa unit ko since i noticed may marka yung sa axle pero matagal madeform yan replacement. way back 2012 nung sa casa pa pms ng unit ko, napakamahal niyang rubber damper na yan, iirc nasa 6.5k ang benta ng mga gahaman at mapagsamantalang tao ng casa. then may lumabas ng mga replacements/copies tig 2.5k. now, i'm not sure pero tig 1k na lang yata yung pair
    Apr 2017
    Hello mga bro!! try to join Montero Sports Exclusive (Seller's Page) in FB... 1k/pair lang replacement rubber damper..
    Oct 2017
    Paps san mo nabili yung rear dumper mo
    ^ kay bos zix. text mo sya dito: 09174659952
    Apr 2014
    The user manual provides for severe vs normal usage scenarios and Time vs distance traveled.
    Sent from my MI 5 using Tapatalk
    May 2011
    While cruising at night with headlights on. Normal ba pag mas madiin ang apak or aarangkada lumalakas yung ilaw (headlights and fogs)?
    Sent from my SM-G930F using Tapatalk
    Apr 2012
    Quote Originally Posted by 3GEMS View Post
    di ko napapansin bro, i think steady lang naman buga ng liwanag ng ilaw. yung wiper ang pansin ko kapag nasa low at bumilis ka at certain speed, automatic na mag-adjust ng movement niya...
    May 2011
    Ill try to monitor further. Pero pag bagong start kitang kita yung paglakas ng ilaw pag aapak sa gas e. Since second hand nabili yung unit nagpalit narin ako battery 3 weeks ago. Sabi ng motolite okay naman daw charger though hindi ko na visual check yung gauge nila while testing. Pacheck ko nalang ulit kung sufficient charging ng alternator ko. Sana wala maging problema long drive nanaman bukas.
    Apr 2012
    i think meron nga issue kung ganyan na di steady yung headlights mo. ingat sa biyahe bro, nabasa ko pa LU ka yata drive safe and enjoy driving along NLEX>SLEX>TPLEX (exit ka sa dulo sa Binalonan).
    May 2011
    Pagbalik ko na mapacheck to bro. Sana wala maging problem sa byahe. Pero nabyahe ko na Manila-Pangasinan-Zamables back to Manila And Manila - Tarlac balikan. Wala naman problem. Pag start sa umaga 1 click lang din. Noted Binalonan bro. Thank you!
    Apr 2012
    usually sa carmen lang din exit ko but i tried all the way to binalonan exit last month na uwi ko. just to see how far the tplex go and have a feel of the newly opened stetch of hi-way. ok din naman, it was fun, masarap magpatakbo😀
    Mas mura ng 16 pesos ang Urdaneta exit vs Binalonan. Derecho McArthur pa labas mo unlike Binalonan na youll have to drive 2 km pa of secondary roads to get to McArthur. Mas maiksi rin ang toll queue sa Urdaneta kasi yung mga hindi madalas sa North, laging Binalonan umeexit kung pa-Baguio/LU/Ilocos.
    May 2011
    Good evening,
    Evaporator ba to mga boss?
    Is this normal na kapag nakaon yung aircon malamig then after engine off 10 mins after mainit naman na medyo nakakapaso?
    ^ been thinking about that too pero hindi pa naman due for replacement iyong sa akin.
    anyone here in the know?
    Good evening,
    Ano nga ba ito?
    Napasilip tuloy ako ng di oras [emoji38]
    when you look into the abyss, the abyss looks into you
    May 2011
    Ano nga ba ito?
    Evaporator ata.
    Engine On/AC on= malamig/freezing
    10 mins after turning off engine/ac = nakakapaso sa init
    Over night engine off/ac off = cold metal lang/malamig
    OC lang baka simulan ng sunog hehehe
    Good am! Hindi ko makita sa thread, ask ko na lang. Pls help. Yung avt touchscreen ko needs calibration/alignment. Hindi ma touch leftmost. Yung mga icons/keyboard hindi aligned e.g. need to tap "e" pero "w" nata tap. Pano kaya ma fix ito? TIA
    Sent from my SM-G900F using Tsikot Forums mobile app
    Feb 2007
    Quote Originally Posted by ojoj22 View Post
    Reset the HU/MID by pushing the pinhole at the leftmost upper side of the HU, then re-calibrate.
    Thanks sir! Try ko later.
    Mawawala na mga settings like preset am, fm, navigator preferences?
    Aug 2005
    Good day mga bossing. Nakapagpalit na ba kayo ng rear w/s wiper ninyo? Yung blade kasi nung sa akin requires replacement na. Do you need to replace the whole wiper or just a blade replacement?
2012 Montero Sport Owners
