Page 150 of 212 FirstFirst ... 50100140146147148149150151152153154160200 ... LastLast
Results 2,981 to 3,000 of 6900
    Jul 2003
    Sa latest gps update fm inav.ph, white na and daylight "theme". I like the icons of Pois and may pics at description na ilang esthablishments.
    Jul 2012
    Sir monty scheduled replacement po yan and no CEL encountered. Try mo power booster on every tank fill up ng diesel, its a petromate product available at petron gas station cost P50 to P55 for a 125ml bottle.
    Sent from my GT-I9100 using Tapatalk
    Apr 2012
    Quote Originally Posted by mangkas1178 View Post
    thanks sir mangkas, try ko yang power booster.
    Jul 2012
    Anong diesel gamit nyo?
    Aug 2005
    It's unioil on my teroy all the ways. Dinadayo ko pa ito from a nearby town just to refill.
    Sent from my GT-I9305 using Tsikot Forums mobile app
    Jul 2012
    Sa akin 13km to and fro magpakarga lang sa unioil.
    Intercooler upgrade biggie size by master ZIX
    Sent from my S3 using tapatalk 2
    Aug 2005
    Mga peeps, may CEL indicator ba ang glx-V limited?
    Feb 2007
    Quote Originally Posted by leinahtan View Post
    Yes sir...
    Sent from my iPad using Tsikot Car Forums
    Apr 2012
    * sir dct, you may want to search the web for possible cause of airbag light flashing then Monday casa mo na ipa-check rig mo.
    btw, I have pressure washer too and had been washing my car body, engine and underbody na pwede mabugahan, wala naman ako na-experienced na ganyan.
    Jun 2012
    oo nga po sir. pacheck ko nlng agad. badtrip lang ba't biglang ganyan
    Jun 2012
    additional problem napansin ko, pag nagshift sa reverse. sobrang lakas ng kadyot. i know normal sa montero ang may kadyot shifting to reverse. pero eto naging doble yung lakas ng kadyot
    Jun 2012
    update regarding our montero gls-v:
    ok na po sya. nakagat ng daga yung wiring sa ilalim. hininang nila para kumabit. so back to normal na lahat.
    paid 410 pesos overall and tip for the 2 technician. may kasama pang car wash, engine wash at tire black ang gulong. ayos
    when installing k&n drop-in filter, do you also need to install the dts chip for maximum efficiency?
    Quote Originally Posted by lakarz_16 View Post
    WOW!!!!!
    thanks
    Jun 2012
    Patanong guys ano kaya problema nung montero namin, humina hatak. Tapos umilaw airbag. Tapos ayaw na gumana speedometer. Thanks
    Feb 2007
    Quote Originally Posted by dct View Post
    Symptoms are contradicting sir, dapat ma scan yung fault code to determine ano problema. Suggest to bring your unit sa Casa for diagnosis if you don't have an scanner.
    Sent from my Nokia 5110 using Tsikot Forums
    Apr 2012
    napa-check up niyo na ba sa casa sir? kung humina hatak malamang fuel filter o scv prob kaya. yung umiilaw na airbag saka speedometer bago yan, interested din ako malaman anong problema ng unit niyo
    Jun 2012
    dun din ako nagtataka sir. iba ibang parte ng sasakyan. airbag, engine, speedometer. isip ko baka may ngatngat ng daga yung wire. sunday pa naman bukas. sarado casa
    Jan 2013
    A possible cause: if you have regular high pressure underbody washing, the water jet could do this damage, particularly if at close range. I have a pressure washer at home and observe how much force can be generated by water alone, if there are sand and soil on the part, it acts like sandblasting.
    Sent from my GT-I9505 using Tapatalk
2012 Montero Sport Owners
