Di na ako nagrequest na pati tank kasi baka inilipat lang na tank galing sa kabilang unit ;)..
Besides, wala naman akong na encounter na CEL...
Sent from my Nokia 5110 using Tsikot Forums
OT: Thanks sir zix for the operation blanking. Will find time for the next upgrade.
Sent from my GT-I9305 using Tsikot Forums mobile app
Sirs may gumamit na ba sa inyo nito: Nano enrgizer (www.nanozr.com).
Sent from my GT-I9100 using Tapatalk
My egr valve & pipe at 20,506km.
Sir leinahtan, 1st 2k petron & shell v power ng nag advised c Sir Zix Unioil na, naka fill up 2x sa flying V 1x sa sea oil kaso lang for every half tank fill 1 30ml power booster ang mix ko on all the above fill up. Bale stopped na ang passage ng exhaust gas sa egr at 17,337km ng nag kabit ko ng blanking plate.
Sir Monty huli ko na po nilinis ang egr medyo makapal nga ang carbon deposit lalo na sa air manifold area medyo basa pa maybe caused by carry over na oil mist ng engine rocker gear cover breather mabawasan narin to, nagkabit na ko ng occ from sir Zix.
Have this one injected on engine oil and already log almost 400km. Nakuha ko sa www.nanozr.ph available at handyman.
Sir leinahtan the red level is for all kinds of cars and trucks and the green one is for motorcycles or smaller equipments. Ang timing ng injection is before change oil that is 1500km before change cause you'll have to change oil after 1500km after injection. After 30k to 50k km pa for the next injection. This is good for cars and trucks with odometer reading or have serviced of 3,000km and up.
Sir for more info try the www.nanozr.com correction on prevoius post
Wow, label po. Thanks. Ako try ko rin to.
My pulled out fuel filter on 20k pms with 20,349km serviced.
* sir mangkas, is it your fist time to replace your fuel filter element? lucky for you to reached 20k kms without getting CEL. others change their filters as early as 6k kms. I had mine replaced at 19k, 23k and 35k kms. all encountered CEL. almost at 50k kms now but still hanging on![]()
