Page 145 of 212 FirstFirst ... 4595135141142143144145146147148149155195 ... LastLast
Results 2,881 to 2,900 of 6900
    Jun 2012
    Mga bossing I need your help.i have a 2012 glx manual transmission.yesterday nov 1, I can't shift the gear?its stucked!cant move to 1st gear 2 3 45 and even reverse.i drove for about 2 hrs to my destination then usual piña yay ko making pag kadating.after. 2 hrs stay I decided to leave.nung pag start ko engine and trying to shift the gear to first ayaw pumasok and sa lahat.tried to close the engine and tried to shift.ok naman sya and tried again to start the engine and shift to first.ayaw at matigas kahit sa ibang gear ayaw.i turned off again the engine and shift to first gear and started the engine waka din.tried to bring back the gear sa neutral ayaw din.pinatay ko makina again and tried to bring to neutral ayaw na.so what I did pinipilit koi baba sa neutral bumalik sya and started the engine again and it worked already.guys anyone any idea bakit at ano naging problem??help.
    Jun 2012
    Quote Originally Posted by Sijay View Post
    Yeah I know it has something to do with the clutch, pressure plate hydra back things.nakakainis kasi napaiyak ako din.one year and one month old palang sya and yet nagkaganun.sad to say today Saturday wala service by have to wait till Monday.i would definitely insist that mayos sya I replace dapat at wag na akong pabalik balikin. We all know that kayo montero bin ilia natin because we believe sa quality Nya so they have to live with it.n
    Jun 2012
    Baka May naka experience na sa niyo na stuck ang gear and can't shift move the gear to any of the shift?travelled 2 hrs then turnoff the engine.after. 2 hrs stay left the place and started the engine again and about to change the gear to 1st, can't move and change.matigas ayaw pumasok kahit sa lahatng gear.any expert or with the same problem?ending pin ilia ipasok then after that nag work na lahat.bakit ganun na stuck sya?i know it's not normal and I just wanna know what went wrong and why? iChat should I do next?
    *Sijay, did you check clutch fluid, is it ok?
    Apr 2012
    covered ka pa ng warranty sir kung 1yr 1month pa lang unit mo. 3yrs or 100k kms whichever comes first ang warranty. pinakamabuti, punta muna kayo ng casa sir at ipa-check niyo para malaman anong eksaktong problema. dun niyo rin malalaman kung may papalitan ba o kailangan kayo bayaran which probably wala. di ka rin pabalik-balikin ng casa kasi as much as possible ayaw nila ng maraming nakatambak na gagawin. ang mahigit 1yr na sayo unit mo so no need to question the quality ng paulit-ulit sa post like kainis and grabe . any moving parts like clutches suffer wear and tear and will fail in due time depende sa paraan ng paggamit. have casa check your ride and then post mo result dito sir...
    Aug 2003
    Di pa ako nagpapalit ng clutch sir. Hinihintay ko masira kasi out of warranty na ako. I am actually waiting feedback sa magpapalit kung magkano at kung pwede mapagawa sa labas.
    First it was the squeaking noise na nilulubricate lang ng casa but has on and off sumptoms. now medyo mahirap i shoot sa gear when downshifting kapag malamig pa. Notchy shifting pa din pag warm na although a lot better. My schedule kasi doesn't really allow me to spend time on vehicle repairs kaya tinitiis ko na lang..
    Jun 2012
    Yes Monty gtv wear and tear sya but for 1 year use lang bumigay na and considering montero?meron akong naging Mga car before at umma about ng 6 years sa akin at never ako nagka problem sa clutch etc.i have asked some tech expert and for one year use masyadong mabilis yun daw and not a wear and tear.yes I am looking forward na madala sa casa yun and know what went wrong and I will definitely post here sasabihin nila so here in this forum Malaman what to do what to avoid etc.atat na atat na Nga ako dalhin sa kanila unfortunately Saturday close.tomorrow nalang Monday.
    Apr 2013
    If Im ask what seems to be the problem of you're GTV?
    Jun 2012
    Quote Originally Posted by jetpilot320 View Post
    Sir non vgt po yung unit ko glx manual.i drove for 2 hrs traffic kasi then when I got sa destination turn off the ngine stayed for 2 hrs then left.i was about to leave started the engine and about to shift the gear to first unfortunately matigas and can't get thru.sa lahat ng gear ayaw pumasok even reverse.i turned off the engine and tried to shift the gear from 1 to reverse at okay naman.so I started the engine again and tried to put yo 1st, ayaw pa din.so I turned off again and tried to shift gears ok pa din.so I put the gear to first and open the engine.kumadyot sya as usual and tried to put the gear to neutral.ayaw at matigas sya.had to force para mapunta sa neutral.then started the engine and it worked already.lahat inaapakn ko clutch pag nag try ako mag shift ng gear.i really don't know what happened and what went wrong.tomorrow dalhin ko sa casa talag bakit nag locked yung gear.any idea sir?tnk u
    Aug 2003
    Suspect ko clutch problem. May problema clutch ng montt, kahit yung akin e. Pacheck mo sir. Dapat under warranty ka pa.
    ^nagpalit ka na ng clutch mo sir?
    Jun 2012
    Hindi thumb drive.one year one month palang sa akin yun.kailangan ba na mag plait na?ang alam ko clutch things sa sasakyan Hindi basta basta nasisira at ng ganun kadali lang.montero low quality?grabe naman.definitely it's a problem and there is something to be fixed and replace.palagay nyo guys warranty pa ba din yun?kainis talaga dahil meron na rin ako naging car dati at wala akong naging ganun problem.
    Jun 2012
    Yeah I know Jayvee clutch problem.checked on the fluid sa hydro back thing ok sya May layman.nakakainis lang kasi dahil one year and one month palang sya.dapat lang na cover pa sya ng warranty cause Mga clutch things sa sasakyan tumatawag naman yun and one year lang?thats definitely a factory defect that I would demand to be replaced.baka pabalik balikin pa ako nun which I won't accept.the reason why we buy montero is we believe in the quality as we'll.tapos ganyan?napahiya ako sa Mga Tao dahil Niro mo kabago bago ganun at nag lock aged?it is definitely not normal sa isang sasakyan.
    Jun 2012
    Jayvee what happen sa clutch mo?pinalitan ba and warranty?sa akin one year and one month palang.baka pagbayarin ako ng repair replacement or pabalik pabalik in ako which I hope Hindi.nag stucked din gear m?grabe!montero pa man din.
    Race chip ftw! Lakas.ng makina ng vgt. Ibang klase! Thanks.master zixx.
    Sent from my S3 using tapatalk 2
    Feb 2007
    Quote Originally Posted by lakarz_16 View Post
    Current setting nyo sir?
    Sent from my Nokia5110 using Tapatalk Pro
    F/c sir. Ang ganda ng hatak.
    Aug 2003
    Sijay, first time ko lang din nakarinig ng ganyan. Hopefully di na nga maulit.
    Jun 2012
    Hi Guys, saan po ba pwedeng bumili ng 3M Matting ung sakto na sa Monty natin all the way to the 3rd row? Thanks in advance.
    Quote Originally Posted by rch_ace View Post
    Custom made yung ganoon sir. If im not mistaken kay autobisyo meron. Im sure sa banawe meron din niyan. Hindi ko lang alam saan exactly.
2012 Montero Sport Owners
