Page 138 of 212 FirstFirst ... 3888128134135136137138139140141142148188 ... LastLast
Results 2,741 to 2,760 of 6900
    next month our rig's insurance will be up for renewal, ours was in-house so now i'm wondering if it would be advisable to still sign up w/ them.
    if your in the same boat as i am, what course of action would you take? enticing din kasi iyong 4 gives iyong insurance policy na offer nila ngayon
    Jul 2012
    * sir baludoy mine due on 10 sep got 6 gives of 40k thru a broker.
    Mar 2012
    Quote Originally Posted by mangkas1178 View Post
    boss, diba masyado malaki yun 40K for renewal of insurance kahit pa naka AOG .
    Jul 2012
    [QUOTE=the_mechanic;2217425]boss, diba masyado malaki yun 40K for renewal of insurance kahit pa naka AOG .[/QUOTe
    Malaki ang napunta sa premium ng OD sa coverage of 1.38M 23k plus ang premium.
    Feb 2013
    40k mahal, kasama na cguro interest dyn kasi 6 gives tapos my broker pa
    kinagat ko na iyong 4 gives ng mapfre/casa + free payong . pero iyong amin a few thousands cheaper than 40k
    magkano ba ang usual cost dapat? kasi sa dalawang quotes na kinuha ko sa 2 magkaibang companies halos parehas lang ang presyo
    Mar 2012
    yun sa akin sir e sa prudentialguarantee (katatapos ko lang po mag renew last July) almost 19T, with a depreciating amount to my original car value of 9.8% ang insured amount, yun nga lang syempre babawian ka sa participation
    meron po ba dito na my bad experience or negative comment sa prudential guarantee? paki correct lang po kung OT. TIA
    mataas yung 40k , sobra.
    nung kumuha ako was 35k , for a gtv, 1.688m coverage. every year bumababa yan kung walang claim. nagrenew ako last march, it was 27.5k
    mga sir's meron na ba sa inyo naka encounter na umiilaw yung signal lights after mag lock?
    http://s8.photobucket.com/user/glaks...1e608.mp4.html
    Mar 2012
    Quote Originally Posted by glaks View Post
    sir, what do you mean umiilaw yun signal light after mag lock, sensya n sir kasi di ma view yun link mo. Kasi sa case ko umiilaw talaga yun pero twice lang after maglock ako, either naka silent mode or with sound. You mean po ba e more than that?
    Quote Originally Posted by the_mechanic View Post
    tama ka bro..pero yung sakin is after mag lock bigla na lang iilaw yung signal lights ko.na post ko na rin sa MSCP meron member na same issue with mine shock sensor daw pinalitan.dalhin ko pa lang sa weekende para macheck.. salamat
    mukhang nagloloko na locking system mo bro. haven't experienced that kind of crazy lights. patingin mo na lang tapos balitaan mo kami
    Mar 2012
    Quote Originally Posted by zix888 View Post
    boss, saan ka kumuha? actually, in terms of insurance I have no idea of which is better, pwera na lang yun sa insurance ng sa company car namin, which ok naman in terms of claims.
    Feb 2013
    Inquire at Standard sa akin insurance coverage of 1m , 16taw bnayaran ko
    The check engine light of my montero came on while running at nlex this morning, upon checking at my engine bay, i noticed that there was black sooth at the lower part of the egr, i also noticed that rust was forming. And there was a crack. Is it possible to just blank my egr without replacing the egr? And may i know where i can have it blanked? Tia
    Jun 2009
    Quote Originally Posted by phelicskit View Post
    If the the CEL occured due to faulty or stuck EGR, its too late already for blanking. Blanking prevents the EGR from being stuck due to hard gunks/carbon deposits. Blanking is for prevention not a cure to CEL.
    Anyway you can initially confirm if you have faulty EGR by listening if you can hear the click sound during initialization every time you turn off the ignition switch.
    Everytime the engine is stopped, the ECU actuates the EGR valve from the fully closed to the fully open. The ECU records the fully closed/open value. It usually compare it with the previous value so if there is a significant change or abnormal value, the ECU lit the CEL at will.
    Try to hear that clicking sound as follows:
    1. Start and run the engine at idle and allow it to warm-up (around 70 degree C).
    2. After the warm-up, turn the ignition switch to LOCK (OFF) to stop the engine.
    3. Confirm if the "clicking sound" can be heard three times (3x) from the EGR valve .
    4. If not, then choose where to go for detailed check. It could be stuck EGR or just a loose wiring of the DC motor.
    By the way. if you hear the "click sound" but the ECU judged the value as abnormal, you have no other choice but to have it scanned/confirmed for trouble code using the diagnostic tool.
    Jan 2013
    Mga sirs,
    Planning to install cabin air filter on 2012 GLS-V, Sta Rosa area, close to 20K PM coming up after 20months, no previous work done on A/C.
    1. Since malamang meron nang build-up of dust/mud in A/C evaporator, would it be advisable to have casa do A/C cleaning before cabin air filter installation?
    2. Any idea of costs of A/C cleaning in casa?
    3. Your experience how often to do A/C cleaning, for those still w/o cabin air filter?
    4. Your experience how much less often to do this after cabin air filter? And your recommended a/c filter cleaning and replacement cycle?
    5. Have anyone used any shop which claim they can clean evaporators without dismantling the housing? Too good to be true?
    Sir Zixx,
    Interested in cabin air filter and OCC. If you have already did DIY to add air filter for 2nd a/c unit, pa share po. Also, meron na kayo idea how to add parking sensors on front corners/ or a chin camera? Thanks!
    May 2012
    my 2012 monty was checked this morning at Citimotors for the Recall. Wla daw papalitan. Feeling great lng. hehe
    Jun 2012
    same here sir,after inspection okey naman daw weld nya.
    just did egr blanking on '09 gls 2.5
    egr blanking on monty 2.5 nonVgt - YouTube
2012 Montero Sport Owners
