Page 132 of 212 FirstFirst ... 3282122128129130131132133134135136142182 ... LastLast
Results 2,621 to 2,640 of 6900
    2way split 3-joint propeller shaft ang 2wd sir.. Makes it 3 greasing points..
    1. Joints between transmission and front propeller shaft
    2. Joints between front propeller shaft and rear propeller shaft
    3. Joints between rear propeller shaft and rear axle housing
    thank you very much bro for clearing this up for me
    Quote Originally Posted by mabuhay View Post
    Maraming salamat sir zixx sa pagkabit ng cabin filter kanina. sa susunod
    nice meeting you sir and madam. thanks!
    Oct 2005
    Hi, Good Day to everyone here,just noticed this month my 2012 GLS-V Monty AT makes strange and weird sound, When i rev my car at 1-2k rpm, the strange sound comes almost together with the turbo whistling or before the turbo, its a loud sharp sound, like a friction, like rubbing the metal, i think its coming from the rear, but i can not sure, anyway, i attached the sound file i recorded this morning, please help me to find out the problem, thank you very much!
    note: the strange sound comes between 00.21sec to 00.26sec and at the end of the sound file
    here is the link of the sound record file
    https://www.dropbox.com/s/gm25xi4f1x...nteronoise.mp3
    Quote Originally Posted by czw2005 View Post
    naidaan ninyo po ba lately sa medyo mataas na baha?
    Feb 2007
    Eto pa sir, exploded view of the propeller shaft-cross bearings ;)
    Jan 2010
    sir prince,,,,twing kailan po ba ang tamang greasing ng propeller shaft?
    Feb 2007
    Quote Originally Posted by rmsoriano View Post
    Sir please refer to item B3 ;)...
    Jan 2010
    thank you sir,. worry ko lang, did the casa have this done during my 20k km pms,,,,, anyway, i am nearing 40k km, i might do this by myself (DIY) kung di gipit sa ilalim ng montero....
    Mar 2011
    If the thud problem is on the 4x2 models only and not on the 4x4. Possible na yung extra joint ang cause ng thud sound.
    Feb 2007
    Very much welcome sir.
    Pwede nyo rin dalhin sa gas station na may maint services offered para ma check nyo kung na lubricate at ipalubricate na rin kung hindi pa..
    Nov 2007
    Hi sir, mine kase is 4x4.. So ilan po ang grease fitting for the 4x4.. Gls se po yung sa akin. Tnx.
    Feb 2007
    Quote Originally Posted by Paj-Man View Post
    Backread lang sir, parehas po kayo ni sir zix(4x4)..please refer to his previous post. ;)
    if 4x2 , walang problema sa mga service stations, kaya nung pang grease nila. but if 4x4, bring some adaptor para sa transfer case, hindi kakayanin ng pang grease nila
    Nov 2007
    Hi, where can I buy the adaptor? Any specific size? Tia.
    3 greasing points ( 1,2 &3 from left)
    1)
    Â*Â*
    2)
    3)
    Nov 2007
    [QUOTE=zix888;2193314]3 greasing points ( 1,2 &3 from left)
    Thank you so much sir. Appreciate it.
    Jul 2012
    Approaching 13k km umpisa ng tumunog ang v belt drive ng ac compressor, naka 2 turns cw na sa adjusting screw nabawasan lang ang tunog. Mga Sirs ano po ang tamang slack ng v belt, o bagay nalang mag apply ng v belt dreasing. Malakas ang tunog during cold start.
    Jul 2012
    Bumigay na yung screen ng HU ko. White screen na lang although may Radio pa rin. Anybody experience such issue?
    hi fellow monty owners. question lang regarding sa steering wheel. i noticed lately na kapag iniikot ko sya may maingay na parang plastic sound. is this normal? mas rinig ko sya when i am about to park.
    May 2013
    Quote Originally Posted by matty View Post
    aw,you not alone,ganyan din sakin, pero afaik wala yung sound dati, parang lately lang nagkaroon.wala naman ako makita sumasabit o kung ano mang pagmumulan ng sound.lapit na 3 months unit namin, tantya ko mga 2 weeks na mula nung magkaroon ng ganung tunog..eto pa, 33 psi front 35 psi rear na ko,pero parang matigas pa rin manibela, dapat magaan na yun pihitin dahil nasasanay na braso ko at nagdagdag pa ko ng psi,,kabado na ko sa steering nitong monty, parang may something..
    aw 2012 pala to,2013 samin, tsuri
2012 Montero Sport Owners
