Page 114 of 212 FirstFirst ... 1464104110111112113114115116117118124164 ... LastLast
Results 2,261 to 2,280 of 6900
    speaking of reserve tires, aside from the oem spare wheel cover, have you guys done anything to ensure its security against theft?
    Sep 2011
    Ako din kanina nag bawas ng ATF kasi over ng 1 inch sa hot level.
    After a 10km drive, binuksan ko agad yung plug sa oil pan. Dapat kaunti lang i-drain ko. Ayun, bumulwak yung hot ATF at napaso ako ng matagal kasi I was trying to close the plug while fluid is pouring out para onti lang ma-drain
    In the end, maraming natapon sa kalsada (i cleaned it after syempre, around 700 ml siguro) and inubos ko nalang laman ng oil pan.
    Nung nirefill ko na, nagdagdag ako ng 80 ml para sumakto sa hot level.
    Lesson learned : Wag magmadali sa pagbukas ng oil pan drain plug. Wag din piliting isara habang ATF is pouring out. Mahirap, mainit ang ATF
    Dec 2012
    Question lang, kailangan pa bang palitan yung wires and fuse if iuupgrade ko yung horn ko from stock to stebel nautilus? tia!
    Aug 2005
    Quote Originally Posted by SeQ View Post
    Although the monty's stock puny horn has a relay itself, when upgrading ensure that they install another suitable relay for the upgraded horn. There is no need to replace the wires and/or fuses.
    Guys, where can I get a Baldwin BD28? Appreciate your inputs.
    no need sir
    Jul 2012
    Sirs, watch out on your tire valve cap.napansin ko nalang early monday morning wala ng valve cap ang 4 na gulong. A day before namasyal ng SM Dasma ang mga apo ko kasama ng kanilang Dad at Mom. Palit nalang ko ng mumurahin.
    Jul 2004
    Quote Originally Posted by mangkas1178 View Post
    Ingat lang talaga sa parking.
    Petty theft is very common this Holiday season.
    Baka ninakaw ng mga Monty haters
    :hysterical:
    mga paps & sir Zix, alam nyo ba para saan ito? ngayun ko lang ito lumabas since i got my monty 6months ago. nung lumabas to nakakabit yung samsung phone ko
    Jul 2012
    Quote Originally Posted by glaks View Post
    Disregard mo lang or click mo yung close (X) para mawala yan. Usual yan kapag nilagay mo sa USB ang ibang brand ng phone (not apple) na may memory card.
    *superblitz, thanks sir sa reply.. ganun na nga ginawa ko. pero naiisip ko pa rin hinde kaya with the correct driver name ma detect na atleast thru USB ng HU natin yung ibang brand ng phone?
    Aug 2005
    no big deal. i have these cheap black plastic caps on mine. they can steal away all fours for all i care.
    Jul 2010
    ^ thanks sir indeed it is informative
    Feb 2012
    On our way to taytay nawala nanaman voice ng gps. Napansin ko lang nangyayari to when pressing the steering audio controls. Ano kaya solution dito? Bad trip lang i have to reset the unit while driving...
    Anyway merry xmas to all monty owners and tsikoters!
    Sent from my iPhone using Forum Runner
    Quote Originally Posted by leinahtan View Post
    thanks t7, I think your were the one who posted this issue on the bypass thread. I was thinking of buying from a certain store in QC carrying the fleetguard flag, I ain't any clue if the stuffs they have are made in Malaysia or US. So, should it be a Malaysian made, does it has anything to do with efficiency compared to their US made counterparts?
    this the u.s. made(latest model 3564) . bought this sa states, last piece, local auto shop in sanfo.
    i drew a line there on top, it is not flat
    the one made in malaysia, the top is flat
    May 2012
    Once in a while talaga dapat ihataw ang monty para lumabas ang carbon. Pag gabi ko usually ito ginagawa. Parang nakakahiya pag bumuga ng usok na itim pero once na mahataw na, ala na uling usok. Uni oil user here since day 1 of use, may 2012.
    May 2012
    7 Months still NO PLATE! Nu ba un!
    Feb 2012
    Been using unioil since day 1 sa monty namen. Meron ba difference sa performance pag gumamit ng euro 2 diesel? My friend fed his patrol with unioil and d daw naging maganda performance at umingay engine nya. Kaya back to euro2 sya. Bakit kaya?
    Sep 2012
    Quote Originally Posted by rap2_tan View Post
    baka hindi pa crdi yung patrol?
    Feb 2012
    Quote Originally Posted by amuro View Post
    D pa nga ata. But i saw jeeps na nagpapa fill up.
    Aug 2005
    Better try euro2 to get the feeling of difference. Doubts still lingers within you, if you havent' tried any. From day 1, I used Shell diesel nitro, at first I thought, the hell with the noise, it's diesel. But when I tried topping up to seaoil until present, the following discriminating difference where felt: subsided engine noise, quick response, and smooth acceleration. Your friend's patrol may not be a crdi diesel type hence the negative performance using Unioil's euro4 diesel. You may advise him to switch back to any of the big 3s.
    - - - Updated - - -
2012 Montero Sport Owners
