naku sir once in a while po ang hataw, not necessarily overspeeding, high revving, shifting on 3.5-4k rpm on 1,2 gears will be fine kung open ang kalye. pero kung 20000kms na madalang ang hataw, build up na ng carbon sa egr yan. even anong hataw hindi na matatanggal yan, cleaning ang kelangan. and yung warning lamp diyan, kelangan ng resetting tool niyan( mitsu laptop). kahit nga palitan mo pa new egr yan kung hindi nireset yung warning, it wont go off
dear zix,
as usual your posts are very informative and help fellow monty owners a lot. they are very much appreciated.
question, how often do you suggest we do this periodic high revving for city drive montys? and how long do you rev it at 3-4k rpms (10-15secs?), how many times do you rev it (until black smoke clears?). this was also suggested at the dealer (high revving and spirited acceleration to burn the carbon deposits). also, their laptop diagnostics may still register no problem, even when your unit emits black smoke at high revs.
thanks a lot.
occasional sprint lang na 3.5-4rpm( if it is safe and open ) not necessarily staying on that rev, and yes until mawala yung heavy smoke. sa case ko naman, every day nlex, minsan upon entry hataw upto 3rd gear tapos cruising na after that, and minsan naman before my exit kung maluwag byahe( kasi high rev on high gear medyo extra careful na kasi high speed na din) . kaya mas okay pa sa first 2-3 gears para hindi naman high speed.
Ask ko lang, nagpa 5k PMS ako last month and the odo reads 6.2k now. Chineck ko kahapon ung engine oil via dip stick and napaka itim nung oil.Dba dapat hindi pa siya maitim? And also 4-5-6 ata ung type of measurement, ung nasa dip stick(correct me if I'm wrong) and nasa 5 ung unit. Sa peak motors sa may pasay ako nagpa pms. Mostly every weekends lang nagagamit ung unit (gls-v 4x2 '12) and city driving. TIA.
may thread dito na halos isumpa yang Peak Motors sa Pasig. next time sa iba ka na lang magpa PMS. malapot ba yung oil or medyo malabnaw pa? and anong klaseng oil ba pinalagay mo? mineral or synthetic?
pag uphill ako nag switch na lang ako to sportronic mode para sure na masunod yung gear na gusto mo.Uphill pa nga. May times kasi na hindi na uphill yun road, hindi pa rin mag upshift yun gear, try ko rin mag upshift using the paddle ayaw rin kasi.
mga sir meron na po ba dito nakapag blank ng EGR? ano epekto? any downside blanking egr? thanks
hi po sa inyo lahat, I got my monte 1 month ago gls-v. Im planning to get some accesories like, headrest and rev cam.
Anu po maganda brand po sa headrest and rev cam? how much po din po?
sir six i blocked it before the egr cooler. you can only have check engine light when you block the hose which is connected to the sensor i guess. as of today wala pa naman check-engine light after 3 weeks of blocking the egr . mine is glx-v
