Page 108 of 212 FirstFirst ... 85898104105106107108109110111112118158208 ... LastLast
Results 2,141 to 2,160 of 6900
    * Sir Zixx, pano po ba ang tamang pag alis ng grill? na alis ko na yung mga plastic screws on top.hinde ko lang alam panong hila yung gagawin ko kasi medyo makapit yung lower part na tatakot ako baka may masira ako na clips. TIA
    Sep 2012
    Mga Sirs sino po ba ang may manual ng alarm ung MMAS ang tatak sa remote...baka po pwede pa post nawawala po kc ung sakin Thanks po in advance
    Sep 2012
    Had my first 1,000km PMS yesterday. I only paid 2,956 pesos...mineral oil lang pinalagay ko.
    After 1 month:
    1. Got my plates and OR/CR from my SA.
    2. No smoke.
    3. No squeeks..
    4. No foul odors sa AC
    5. They replaced the alarm module....for free.
    6. Good acceleration...(nerbyoso lang driver kaya d maka lagpas 140...LOL). Very stable po si Monty sa 140.
    7. Good fuel consumption....wla nga lang syang estimate sa HU...GLX kc.
    With these I consider myself a satisfied Monty owner...2012 GLX MT
    BTW...Help po mga fellow tsikoteers...baka po pwd makahingi ng manual ng car alarm...ung MMAS ang tatak...nawawala po kc ung sakin TIA
    Quote Originally Posted by glaks View Post
    basta the motion should be towards you, kung nakaharap ka sa grill, not upward nor downward
    Quote Originally Posted by zix888 View Post
    salamat sir..subukan ko ulit mamya pag uwi.
    Quote Originally Posted by leinahtan View Post
    I'm no expert on oils. I don't know if this has significance:
    Is it Delo 400? because the Delo range consists of the following:
    Delo® 400 Multigrade
    Delo® Gold Ultra
    Delo® Gold Multigrade
    So which of the 3 are you referring to?
    i think sir miko is talking about this one
    tested them already, easy 10000kms with bd28
    Sep 2012
    mga sir normal ba ang idle white smoke? medyo masakit din sa ilong yung usok nya, seaoil gamit ko diesel since day 1, mits turbo xp fs oil ang 1st pms -1.5month old monty glx non v
    Sent from my XT910 using Tapatalk 2
    Jan 2011
    mga sirs... anyone of you experienced error on playing your usb? my LCD screen showed "vo Filter Error --- Unknown error (OXFFFF0004). The song contents of the usb can be viewed but it doesn't play the songs. Pls. help what to do to correct this error. Many thanks...
    Aug 2005
    Quote Originally Posted by puroiskii View Post
    I have the same oil from casa during my rig's (GLX-v Limited) 1st PMS. Although I was using Shell diesel Nitro since 1st replenishment that time. But, I already switched to Seaoil's Bioexceed diesel about a month ago up to present. I never noticed white smoke on idle or even start-ups. The best part after the fuel transition is the engine became responsive and quieter.
    * sir zix, thanks for the clarification. Will give both (delo & bd28) a try on 10k km.
    Quote Originally Posted by ACC View Post
    usb fix kelangan mo sir, version update.
    Sep 2010
    sir ok na ulit monti ko nawala yung usok nung nag linis ako egr pero after bumabalik padin. dinala ko na sa casa SQUILL test nila and calibrate yung fuel ejector ayun natumbok nila salamat naman. ang maganda wala ako binayaran dahil warranty.
    Jun 2012
    Salamat sa mga reply sir, subukan ko siguro ung Royal Purple 15w40 paired with BD28.
    Another question, ung mga nagpalit po sa inyo ng BD28 ng 10K e nagpalit nanaman po ba ulit ng oil filter sa 15K pms? TY
    Jan 2011
    sir zix pano po ibig sabihin nyo ng version update? Yung sa unit po ba o un usb mismo? sorry di masyado marunong. tnx sa reply.
    bale sir may file na needed to put there in your sd card(navi). upon start up, automatic po mag uupdate to fix your usb problem. winterpine can do it for. if easy access po yung sd card niyo, i can send you the file
    Feb 2011
    Sir zix888 can I ask a favor? Pa send naman po ng file para maayos ung voFilter error... ganyan rin kasi nangyari ngaun sa unit ko. It would be a lot easier for me to do it myself than bring the monty in winterpine... thanks in advance sir...
    Jun 2017
    Sir zix888, I'm newbie member po sa tsikot, good day po sa lahat. Just saw this old thread/post regarding the "vo filter error" when using the USB multimedia port in my montero sport 2011. Matagal ko na po hinahanapan ng solution ito and now I think i found the fix thru your post . I have an easy access for my SD card. Kindly share po ung software update . Salamat mga sirs.
    mga sirs,
    makisakay lang sa usapan ng h.u.
    anong pwedeng ipalit sa stock h.u. natin (pref android) na magagamit pa rin yung tpms? nagsasawa na kasi ako kaka-calibrate nung touch panel. 5mins pa lang after calibration, pahirapan na ulit gamitin. almost 7k daw ang palit ng touch panel sa winterpine.
    salamat
    Quote Originally Posted by 99gil99 View Post
    mga sirs,
    salamat
    Sir pano nyo i calibrate yung touchscreen? Need to calibrate sa akin kasi. Thanks
    Sent from my SM-G900F using Tsikot Forums mobile app
    Quote Originally Posted by ojoj22 View Post
    setting > screen calibration > yes
    ang challenge paano makakapunta sa screen calibration kung hindi ma-click yung settings
    Quote Originally Posted by olympiah View Post
    Balak ko din sir magpalit. Try nyo Autolink sir. May package sila including steering wheel 2016 upgrade.
    salamat sir
    You can bring your unit at Winterpine Service Center, Aurora Blvd cor Hemedy. If its still under warranty they may replace your HU. Otherwise costs will apply.
    Sent from my SM-G920F using Tsikot Forums mobile app
2012 Montero Sport Owners
