Page 98 of 124 FirstFirst ... 4888949596979899100101102108 ... LastLast
Results 1,941 to 1,960 of 5006
    Mar 2011
    actually may problem ako... nung nagupgrade ako to 3.0 gumana naman. but sa kakatanggal ko ng sd card, parang nacorrupt sya. so parang ayaw na basahin. so nireformat ko yung sd card. ayaw na sya mag upgrade to 3.0 kasi parang ndi na nya mahanap yung program ata... so nag manual copy na lang akk nung 2 folders... kaso nung sinaksak ko ulit sa gps, gumana sya, pero parang garbled yung streets... parang corrupted.
    apart from the 2 folders, ano pa po ba laman nya...
    thanks.
    Posted via Tsikot Mobile App
    Sep 2013
    Quote Originally Posted by mike879 View Post
    thanks.
    sir dalhin niyo yan sa casa or sa winterpine pagkalam ko po rereplace nila yan, may isa na rin sa ibang thread na ganon nangyari pinalitan yun para sa kanya
    Feb 2007
    Na back up nyo po ba yung SD Card nyo bago yung update?
    thanks to "gab",
    for my illuminated cigar lighter. i just finished installing it. ginabi na, haha
    Mar 2012
    Quote Originally Posted by zix888 View Post
    thanks to "gab",
    ganda nito boss...
    my guide or instruction kaba kung paano baklasin yun panel na eto. my assignment kasi ako this week (DIY), Im replacing the switch I made dun sa DRL and put it here. May nabili ako kasing switch na push button, na pwede dito ilagay. problem ko lang e pano eto baklasin na hindi masisira.
    Quote Originally Posted by jalen View Post
    sir mechanic gaano kahaba ang sd extension cable...48cm pwedi na ba..??
    pwede na yan bro, only one position nga lang na aabot yan.
    Mar 2011
    hi. can someone send me the files dun sa sd card ng gps? only the files outside the 2 folders... meron na ako nung files galing sa inav, so only small files. kaso naformat kasi yung card, so nawala yung iba. thanks... kindly send sa mikeko879*yahoo.com. thanks.
    yes, i am going to winterpine pag ayaw. medyo la pa kasi akong time. salamat sa tutulong.
    Jun 2008
    Mga sir may malaking problema ako. A/T yung montero gls ko.
    Nagloloko yung transmission niya. Ganito po..
    While in "Drive" mode, bigla siya nagiging "Neutral".
    Dashboard display: From "D" suddenly nagiging "N".
    Autostick/Stickshift: Nakalagay parin sa "D" pero naka Neutral na yung mismong transmission.
    This usually happens when I'm driving below 40km/h and when coming to a full stop.
    I tried searching the net regarding shifting problems and gear slipping, and saw that it might has to do with transmission fluid or worst, the transmission wearing out.
    Nangyari na ba sa inyo to? As much as possible ayoko iderecho sa Casa to, for sure masakit-sakit sa bulsa yun.
    Hoping may makatulong sakin.
    Thanks!
    Apr 2012
    Quote Originally Posted by yuyuti View Post
    Thanks!
    similar case posted before in one of the mitsu thread. the fault is the inhibitor switch in the transmission. search mo ang inhibitor switch...HTH
    Jun 2008
    I changed my ATF earlier, for maintenance purposes and hoping sana di na mangyari yun.
    Will look at that.
    Thank you!
    Newbie here in this forum. A little history on my 2011 glsv. got it at a 2nd hand car dealer at 18tkm last june 2013 without a manual and warranty handbook. Had it pms at 20tkm and 30tkm at casa nearby my area, they recommended replace front brake pads on my next pms. Now at 33tkm the abs warning light on my guage is on. Anyone here shops with obd scanner where i can opt to go for diagnostic? Planning to go out of casa for my coming pms. Inputs will be much appreciated. Tia
    Sep 2010
    Quote Originally Posted by lloyd_tiff View Post
    sir pm mo sir Zix meron sya.
    Dami ko ntutunan sa forum na to.. Puyatan sa backreading ng mga posts..
    Mga bos, anyone here knows how to go about these faults:
    [U1102] [Mitsubishi] ASC/TCL/ABS timeout/Not equipped
    [P1769] [Mitsubishi] Stop lamp switch
    After clearing the faults on Torque it says:
    2Gray fault codes might only be clearable by the ECU itself after 'N' fault-free drive cycles have completed
    Does this mean i have to use the car for a certian period for the ECU to clear it?? (I havent drove it after clearing the faults though, its my coding day)
    Any inputs will be much appreciated, newbie here trying out DIY diagnostics and to turn off the ABS warnjng light on my dash..
    Sep 2011
    Sirs/Mams goodevening.
    May alam ba kayong shop aside from casa that sells the mitsu emblem? The one na nasa harapan ng montero.
    Ours got stolen 2 days ago. Ginamitan ata ng screwdriver/knife.
    If you have extra/accessories, paki PM ako sirs/mams.
    Baka magustuhan ko haha.
    Thanks!
    Apr 2013
    BTW im selling my old oem fmic ng montero lahat kasama pati pipings. 2013 model yung akin kaya sariwa pa, 12k lang tinatakbo ko. Pm me if interested. Salamat.
    Sent from my iPad
    Feb 2007
    Haha akala ko may spammer na! :D
    Yung matataas na mileage at walang OCC sigurado maramin oil yang IC nyo kaya kunin nyo na, mura lang yan for sure! ;)
    Sir Beng sent you a pm.
    Sent from my Nokia 5110 using Tsikot Forums
    at last
    285 45 22s
    kahit i-drive pa ni mrs, may laban pa rin sa mga lubak
    Jul 2013
    nice shoes sir zix :D
    like it!
    Mar 2012
    Hi Zix.
    Nice meeting you earlier. Thanks for the filters & the quick egr blanking. Ewan ko kung psychological pero parang mas maganda nga ang takbo with the blanked egr - (will have oil changed & filters tomorrow pa). After the oil change, byahe sa Tagaytay para ma-subukan with egr blanked.
    Idol, partner!
    Will be in touch.
2011 Mitsubishi Montero Sport [continued]
