the original steering remote was dismantled and replace with the IR module for pioneer sir. line goes inside the steering cover.
sir 2011 and up montero has the 2din avt monitor. separate pa din ang 1din head unit. as compared to this i installed a 2din head unit together with a oem challenger center console so that it will fit perfectly.
thanks again
sorry sa kulit. so you mean you installed a single DIN center console (from the australian mitsu challenger) where the old AVT HU used to be? ...then replaced the AVT monitor with a pioneer double DIN HU?
got it na. i'm thinking, is it possible to find a pioneer single DIN HU then output its video-out to the AVT monitor? parang nakakapanghinayang kasi na hindi gamitin ang AVT monitor. may ganun kayang HU? ...na pwedeng tumanggap ng touch input from an AVT monitor?
can i ask saan ka nagpa-install? i'm thinking magaling siguro ang nag install ng system mo para ma-incorporate ang remote control ng pioneer sa steering wheel remote ng montero.
also, pa-PM na din where you got the challenger center console?
maraming maraming salamat
edit: btw, nice pics! pwedeng pang brochure ng pioneer and/or mitsubishi
can u take a pic of your new steering remote sir?its bought together with your 2 din and center console right? or was it bought separately?
*jasapix,
sir how about the AVT GPS? how did you transfer this to your pioneer?
Mga Sir question lang....
I purchased my monty around february and last satruday night while nag drive ako the check engine suddenly lit,
my question is meron na bang ganito na nangyari sa ibang 2011 monty? and what kaya ang problem why it lit and this early?
TIA
My monty has around 10kplus mileage sir, i just underwent change oil last week....
the casa called it was due to a dirty fuel filter daw... and madumi daw ung diesel ko....
this seems to be odd pero isang gas station lang pinakakargahan ko and i use premium diesel pa (Turbo diesel) so does it mean na these kind of diesels are not advisable? if i switch to seaoil/unioil for their EuIV does it compromise the performance? TIA again
-Update
I just found out that may fuel filter needs to be replaced even my diesel will be drained -.- this is very frustrating.......
Hi sir, had no problems with my GTV yet... Got it last may and just had my 15k PMS last week.Originally Posted by obek
Been using vpower for a month then switched to seaoil after learning it's cleaner diesel (euro 5). Walang usok and power comparable to shell's. Was reluctant at first kasi never tried seaoil's products but very satisfied now.
Petpeeve ko sa shell you need to switch off your engine before they fill up. Eh naka turbo timer ako so really frustrating. They offer credit cards, motor oil, windshield cleaning. Imagine everytime you gas up you'll hear this. Very annoying.
Sa seaoil wala... They don't care. Which I like.![]()
You must also check the location sir. Make sure hindi flood-prone yung area. Baka may flood water which makes the diesel dirty. I fill at seaoil Edsa after quezon ave.Originally Posted by obek
Ok naman. They even gave me cash when I used my credit card. I think promo yun just forgot how to qualify. Just a thing, when I go out of town walang seaoil! Or I say very limited... so I make sure fulltank na before leaving the metro.
* obek
If your tank accummulated dirt that fast, madumi talaga diesel nung gas station mo. Huwag ka na bumalik dun sir
seemed unusual nga
but, you can never tell
there are some gas stations where i avoid, even if it is nearer to my location, simply because they get flooded even during moderate rains (e.x. pasong tamo near makati cinema square)
i was a petron diesel max user before trying out seaoil
i had no problems with either
i am still on my third top up with seaoil and will continue to observe if it is, indeed, better than petron
seemed unusual nga
but pricewise and with the seaoil vip card rebates, mas mura nga ang seaoil, hehehehe
