Page 69 of 124 FirstFirst ... 195965666768697071727379119 ... LastLast
Results 1,361 to 1,380 of 5006
    May 2005
    winterpine changed my MID for the 3rd time. buti na lang wala na yung old stock and they replaced it with the 2013 edition. hope this will last naman. complained that they have removed the panel more than 10 times already, pinalitan na nila ng bago
    Jun 2012
    Quote Originally Posted by fireblade View Post
    Sir may I ask what is the problem that they have to open the panel more than 10 times and they have to replace the unit? TIA!
    Jul 2004
    Quote Originally Posted by k1dlat View Post
    You have to remove the panel to get to the RV meter and/or to check the connections
    - - - Updated - - -
    May 2005
    gps, rvmeter, microphone repeat two times, plus upgrade of map, wrong corrupted card, repeat two times.
    there you go, lamog ang panel cover.
    Jan 2011
    Sir what is the difference ng 2013 sa 2011 na HU?
    May 2005
    Quote Originally Posted by tuazon7 View Post
    screen is blue initially when you power up then it becomes black red and gray. also, it is now tv tuner ready i was told.
    Jan 2011
    Thanks. Pa post naman ng pics once you have time sir
    May 2005
    Here you go sir....
    Jan 2012
    Here you go sir....
    Sir gumagana na po bang tv tuner? or kelangan pa ng antenna
    - - - Updated - - -
    Here you go sir....
    to
    relocated the reverse cam to have a balanced plate lighting
    Feb 2007
    Quote Originally Posted by zix888 View Post
    to
    How did you relocate the camera sir? You mean binaklas nyo yung casing? ;)
    Quote Originally Posted by glaks View Post
    i think kailangan pa rin ng tv tuner which is around 8k kay winterpine
    4500 lang ang avt tv tuner sa banawe.
    May 2005
    Quote Originally Posted by beni23 View Post
    pasok sa head unit natin sir? kasama na ba ang antenna?
    invert the whole piece, now the camera will be on the left side, remove the camera from the assy(2 screws) so you can rotate it 180 degrees(if not the camera is pointing up and you cant mount it)position it a little bit down around 4mm( medyo mas masikip na kasi yung area na yon) then screw it back. mount the whole thing , thats it
    Apr 2012
    This is very nice, sir. Wala ba problem with the display in our MID specially the distance from objects? Thanks
    Apr 2012
    Sir, tried doing this during the weekend in my 2012 GTV. Mukhang magkaiba tayo ng model ng back-up camera. In the 2012 model, the camera itself cannot be removed and rotated. One piece assemply type. I was able to remove the 4 screws at the back cover of the camera and saw that it was fixed and part of the assembly. I was thinking of interchanging the plate 2 lights, i.e. light with camera transferred to the right, but the wirings were too short. Besides, di tayo sanay gumalaw ng wiring...hehehe.
    - - - Updated - - -
    Quote Originally Posted by NAML View Post
    wala naman sir, actually halos wala pinag iba sa view niya before eh. ang big difference is yung buga nung light niya sa plate eh balanced talaga
    Apr 2012
    Thank you, sir. This will be my very first diy sa auto.
    Feb 2007
    Thank you sa tip sir zix. Actually, planning to replace the camera module too kasi nawala yung lines sa nakakabit ngayon, buti na lang may extra pa na unit..
    my year-ender diy
    rain and light sensor installation
2011 Mitsubishi Montero Sport [continued]
