Page 6 of 124 FirstFirst ... 23456789101656106 ... LastLast
Results 101 to 120 of 5006
    Jan 2010
    I think you have to force control it sa Timer in case of emergency, not sure tho because I don't have it in my unit, or maybe install a separate by pass switch. But your concern is very valid, especially during emergency cases.
    Quote Originally Posted by jaejae View Post
    wala po bang safety issue ang turbo timer? di po ba pag switchback mo ng key to off position, di po mag stop yung engine but rather run for a pre set time then stops automatically? what if po in an emergency situation that you have to stop your engine instantly?
    double post
    you can turn off the timer manually, it will in then turn off the engine in case of an emergency.
    Aug 2007
    just push the single button on the turbo timer, it will instantly shut down
    May 2011
    +1 ako kay bikoy888
    you can override the turbo timer, just turn it off.
    May 2011
    Quote Originally Posted by raymond022091 View Post
    salamat po.matanong ko lang sa mga naka MS bakit parang wala nakalagay na sensor sa mga tire kasi hindi gumagana yung sa tire condition sa screen.
    GTV comes with the tire pressure sensors installed. The GLS-V has a provision for the sensors, but it's an extra 15k for them.
    Mga sirs with regards sa turbo timer, it costs just 2,500 more or less (miccon, volution, amata, etc.) and it really serves a function. Compare this to putting mga add ons sa MS na doesnt serve a purpose but just to add bling to the car, I think installing a timer is a wiser move.
    Quote Originally Posted by ARB View Post
    If you have the budget, it is indeed a wise and safe move. It will make sure your turbo won't fail you for the length of its service.
    Feb 2007
    sir additional po yung tpms sensor sa budget...about 15k po yata. tpms ready lang po yung MID ng GLS-V...
    May 2011
    Kaya naman pala..mahal din pala.hehe.salamat mga sir
    Feb 2011
    Weird turn signal prnoblem, when I switch the toggle to the right, the front left signal lamp is the one that turns on and when I turn the toggle to the left, the right signal lamp turns on. Hmmmm....
    Quote Originally Posted by rafmac View Post
    madali lang yan boss, dun lang sa switch niya sa parang isang box yan. Babaligtarin lang. May binaklas ba sa ride mo sir lately? Baka nahugot yun at tapos nagkamali ng balik?
    Feb 2011
    Thanks. None in that area, but will bring it to the casa this saturday.
    Share ko lang latest upgrade, knn filter and commonrail box, grabe ang difference in power, still monitoring the comsumption
    Jul 2004
    what is the commonrail box for? does it function similar to a racing chip?
    Yes sir same po
    Mar 2011
    nice. san po kayo nagpa install? how much? pwede din po malaman why did you choose [any advantage] this one compared dun sa ibang brand? tia
    Quote Originally Posted by zix888 View Post
    Quote Originally Posted by gundam View Post
    Yung cr plus nakuha ko almost 20k converted to peso from australia, pang mitsubishi challenger, tested na nila kaya nagdecide ako na ito kunin, plus german made siya. Yung filter naman thru knn site from u.s., almost 2k when converted to peso, pinakisabay ko lang sa friend ko na umuwi dito pinas.
    Ako lang nagkabit, plug ang play ang connectors, ang trick lang is you need to remove the battery para maiconnect sa common rail pressure sensor yung connectors, madali lang actually. Solve ako talaga, ibang iba ngayon ang hatak
    Mar 2011
    thanks.
    how does it work? looking at the box, is that a dial to adjust the setting?
    there's also a graph, how much hp/torque gains?
    thanks.
    Now its 216 hp , 414Nm torque with the gain setting of no.6
2011 Mitsubishi Montero Sport [continued]
