Page 58 of 124 FirstFirst ... 84854555657585960616268108 ... LastLast
Results 1,141 to 1,160 of 5006
    Aug 2012
    mga sir wala ata stock ngyn glx non vgt. mag 2 weeks na ko mag antay unit ko from citimotors makati.
    Aug 2012
    mga sir need your help. newbie here just want to ask what might be the problem and what particular part po montero ito? may oil leak po kasi. and am i in the right thread? thanks in advance
    Aug 2012
    Quote Originally Posted by zix888 View Post
    pag SA tinanong mo kasama yung fuel filter. when i changed mine * 20kms, sobra ganda pa nung condition nung fuel filter, nanghinayang nga ako eh, kaso nabuksan ko na, so palit na ako. pero i suggest if magpalit ka, huwag yung oem, sobra mahal, meron mas maganda, mas mababa pa price. sa air filter, i guess wala ka iba choice kundi k&n
    Zix anong fuel filter gamit mo?
    Problem with knn is yung oil spray. Pag sobra, masisira yata yung maf sensor e.
    baldwin pa rin syempre, the best fuel filter.
    ang secret sa k&n recharge, after cleaning and recharging, let it settle for 3 days, back to the old oem ka muna while letting the oil sprayed to settle, and let the excess oil to drip, pag nagsettle na, wala ng problema
    Mar 2007
    hurricane air filter puwede rin
    Sep 2011
    Goodevening Sirs. Anyone of you experienced engine hesitation at high RPMs? Yung aarangkada ka then kapag tumaas RPM mo, nawawalan ng power. 2nd time ko na naexperience ito e. The first one was months ago, nag fill up ako sa gas station on the way to tagaytay. Probabably water contaminatin. This 2nd one, sa suking gas station ako nag fill up. Any possible reasons? Thanks!
    Apr 2012
    sir zix, saan po kayo nakabili ng baldwin fuel at oil filters? i think till now wala pa yata avail dun sa volmax shop na nagbebenta...TIA
    Jan 2009
    Sir Zix, paano kayo nagbaklas ng fuel filter? Concern ko kasi if may trap pressure ba sa fuel hose na dapat pag-iingatan habang binabaklas? tsaka yung priming ng new filter paano procedure ginawa nyo? Thanks.
    Quote Originally Posted by Pidok View Post
    i used a towel underneath for fuel spill from the hose upon disconnecting from the filter. disconnect the wire connected from the filter, then remove the fuel filter assy. mas maganda kung may ready ka na diesel para pang-fill up sa new filter. replace filter( medyo tight yung bottom part used a "gato"). when everything is in place, just pump it 'til it gets hard. no trick or anything, pretty basic. one click starting nga siya after the change
    Jan 2009
    Thanks Sir Zix. Then hand tight lang ba yung new fliter?
    May 2007
    Pumapayag ba VV casa kung may dala ka sarili fuel at oil filter during PMS? Wala ba ma-void na warranty?
    Thanks!
    Feb 2007
    Quote Originally Posted by SRGuy
    Thanks!
    Payag sila sir, contact your SA in advance para informed din sila.
    Aug 2006
    SD Ext and Keyfobs:
    Boss pa PM na lang ng instructions kung paano oorder ng 2 SDCard Extension
    Thanks!
    Feb 2007
    PM replied po mga sirs ;)
    May 2012
    Sir Prince, eto itsura nang keyfob nang Non VGT na montero. Baka may makuhanan tayo nang key fob
    Feb 2007
    Sir meron pang Nissan.
    Magiging Nissan Montero!
    May 2012
    Hmmm, mas maganda itsura nung sa Montero na key fob!
    Feb 2007
    Yes sir kasi 2-buttons lang yung keyfob kaya neat din tingnan. ;)
    Pag medyo tumagal sir meron na rin siguro lalabas para sa remote na 4-buttons.
    Sep 2011
    Just want to ask kung normal LNG ba sa Monty na nababawasan yung coolant sa reservoir, just had my DIY 20K Kms maintenance, kala KO yung coolant ok pa level sa reservoir yun pala mantsa lng Nung deposits nakikita KO sa labas, pag bukas ko Nung filler cap konti n LNG laman Nung reservoir halos matutuyo na, although pag nasa operating temp sya dumadami ng konti galing sa radiator, TIA
2011 Mitsubishi Montero Sport [continued]
