Page 38 of 124 FirstFirst ... 283435363738394041424888 ... LastLast
Results 741 to 760 of 5006
    Apr 2011
    Sir zix888 may cruise control ba 2011 gtv o pinakabitan nyo po? If yes, san po pwede magpapalit?
    Quote Originally Posted by dohcvtec View Post
    Wala po cruise control yung 2011 gtv, diy ko lang. , bought the parts online. hindi pa kasi alam ng casa and winterpine how to install and make it work kaya no choice. Had to do some connections sa ecu to some connectors . yun yung critical sa diy ng cruise control
    Apr 2011
    Quote Originally Posted by zix888 View Post
    Grabe ang talent nyo sir. Kelan kaya pwede magpakabit sa kanila sir? Pano warranty nyo sir?
    Have to check muna sir if your monty is compatible. Any wiring naman na done out of casa, (kung casa ang tatanungin) sigurado void ang warranty. Will post some vids on how it works on 2011gtv, tamang tama may long drive na naka schedule.
    Jan 2011
    bro, got my parts yesterday for my Cruise and Paddle DIY. got it from my contact, really good price. just need some spare time to finally complete these DIYs. did you use a puller ba to remove yung steering wheel? Will do these along with the corner sensor and ASTC switches but pang ibang functions ko na lang gagamitin itong mga ito. Yung corner for the rear camera activation na lang even when at 'D' tapos yung ASTC, reserve ko na lang muna for the WA after the warranty expires...will post pics tomorrow...
    Quote Originally Posted by tuazon7 View Post
    Pm me sa pricing bro. Ganyan din yung current diy ko, always sonar off illuminated, then pagreverse, tsaka mawala yung illumination. Yung astc, 2 lamps yun, red astc symbol and amber astc symbol with the "off" sign, bahala ka na mag assign kung san mo type. Mine is also waiting pa kung san ko isasabay if hindi matuloy yung astc diy ko. Were you able to do your seatbelt lamp, may kasama kasi tayo na naka glsv, hindi niya mapa illuminate eh
    Feb 2007
    Thanks sa video sir zix.
    Where is the SD card located? Forgot kasi when the map was updated last time at 41. Accessible na ba sya once the cover is opened?
    Jan 2012
    gusto ko ng palitan ng bagong sounds system ang monty ko.... d ko alam kung anu best package.. all i want is ung clear na sound na tunog altec lansing basta kahit hindi malaks ung sakto lang pero buo ung tunog nya at ung kabog ng bass hindi sabog... mga magkano kaya un.... can u suggest a good sound installer / technician?
    Somewhere below those sd cards.
    Jan 2011
    bro, get ko permission mo to share this pic sa MSCP ha? para ndi na ako magbukas pa...TIA.
    Okay bro. Ask ko pala regarding cabin filter, yung part na i-cut out, tinanggal mo ba siya o in place cut out? Tia
    Jan 2011
    Thanks bro. Yun sa cabin filter, in place cutout bro. Hindi naman lalagpas yun cut mo dahil meron groove, ingat lang sa mga na cut mong plastics baka mapunta sa blower...
    Goodbye battery!!! ( on my steering wheel audio remote )
    montero sport gtv 2011 - YouTube
    Jul 2004
    ito din ang gusto kong DIY
    Feb 2007
    Pa suspense pa sir Zix ha!
    Share naman the DIY!
    Thanks..;)
    Thanks..;)
    Sir madali lang yung diy nung sa battery, LM-317T and resistor to get a 3V output. Ang problema lang sir na nakikita ko for 2011s is yung kinuhanan ko ng supply ay galing sa harness nung cruise control ko. Kelangan palit pa kayo ng clockspring just to get power supply.
    Feb 2007
    Thinking of getting the 12V supply to the ignition.
    Found this cuircuit, will check kung pwede..
    The problem bro, from the ignition going to the steering wheel , without the connection thru the clock spring, the wire will get twisted as you turn the wheel
    Feb 2007
    There should be a power source on top of the clock spring, am thinking of the horn switch. Ito siguro pwede pero kailangan yung circuit is small enough to be hidden behind the cover..
    Jun 2010
    Mga sirs, what diameter size ba yung front and rear speakers natin? Planning to change the stock speakers kase with separates sana. Kasya ba ang 5 incher sa harap or is this too small? Will it void the warranty even if no amp will be used? Talagang palit speakers lang.. Just got my white gls-v today but a long time lurker dito sa mga forums. Thanks in advance!
2011 Mitsubishi Montero Sport [continued]
