Page 3 of 124 FirstFirst 12345671353103 ... LastLast
Results 41 to 60 of 5006
    May 2009
    mga sir, anyone tried if pwede palitan ng key ang 2009 SE to 2010 - 2012? kasi yung sa mga 2009 separate ang key and remote. plan ko sana mag change to 2010 key, yung built-in na ang remote sa key. paging sir ZIX... hehehe
    2009 key
    2010 and up
    Apr 2011
    anyone here selling their montero?
    sir bakit?
    Jan 2013
    Hi, Newbie lang sa forum. Question lang, I just bought 2009 MS 4x2 AT Diesel, pero walang owner's manual. Saan kaya ako makakakuha nito?
    Thanks!
    Apr 2012
    sir, i sent you a PM...
    Apr 2012
    puno inbox mo sir, i'm sending you a PM...
    May 2011
    Guys anyone here with V-kool installed on their windshield comment whether GPS signal is interfered? Thanks
    May 2009
    Vkool po sa windshield at sa front seats side windows.... wala naman po prob sa GPS....
    May 2011
    Thanks jaejae! Nice ride By the way.
    Nov 2013
    mga tol, tanong sana ako if meron bang wood panel na binebenta for montero 2011?
    Sep 2014
    mga bossing.. sir paki suggest po. i have my montero sport GLS AT2010 model
    pag start ko po aandar po cya to 1 to 2 secs lng mamatay,kala ko pump lng alang krudo, di eh ganon parin. pag start mo 1 to 2 secs mamatay. paki tulong po.. please...
    Bros., a relative's HID headlight is busted.
    Can anyone please advise where can we buy HID headlight assembly? And approximately how much?
    TIA...
    Aug 2009
    Quote Originally Posted by kutangbato View Post
    yes sir it has cable for back up camera. un headrest monitor lang ang wala at si winterpine lang meron nito.
    sir you mean to say 8.7k ang damage mo for the headrest monitors..AFAIK sir, nakuha rin ni koy of carland un wiring for headrest monitors sa winterpine sa pakiusapan pa.
    Yes, napakiusapan lang ni Koy yung kilala nya sa Winterpine and 3 pairs lang ata nakuha nya including mine. Yung 1 pair napunta ata kay md_alcapone. With regards to the back up camera attached to the plate, ginamitan ko ng allen bolts para di madaling manakaw...
    Apr 2011
    Quote Originally Posted by Slick50 View Post
    Hi Guys
    Those of you who have a GTV is it normal for the manual shift to shake (epileptic).
    I was shocked that the sound system of the GTV is pretty good. Makes me wonder if I should have ordered all the sound system from the states. LMAO.
    I found the low beam HID severely lacking in illumination.
    Will report more later.
    Hi Sir Slick, correct me if im wrong, your low beam is 6000kelvin right? Mine is a white GLS-V and I changed both my fogs and headlamp with 6000k, with the headlamp installed by winterpine and fogs by kid audio. I share the same observation with the headlamp, not quite bright enough which is a bit dis-appointing and would have it checked when i return to amcar for my units' 5k check-up.
    Jul 2006
    Quote Originally Posted by metslgx View Post
    My GTV comes stock with 4300K HID low beam. I visited Garyq - HiD Retrofit God. Apparently the lens they used for the project is ribbed vs clear lens. Clear lens produces greater and wider output. I also suspect they used generic HID bulb. I've tried to find out what type of Hid Bulb they used but can't get a answer. If it is a D2S type, I am planning to purchase Philips +82122 which is the best HID bulb around. With regular use you should get 7 years before you need to replace them. They're output is 4300K 3200 lumens.
    I've discuss with Garyq about replacing the H1 high beams with Morimoto Mini D2S Projector Type III, 50 watt Morimoto Ballast and Philips +82122 HID Bulbs.
    Upon further contemplation, I've decided not to upgrade the Fogs to HID anymore.
    Here is what Morimoto D2S mini Projector with 50W Morimoto Ballast and Philips +82122 will look like...
    Low Beam
    Hi Beam
    The beam is intense at the same time does not produce glare to oncoming traffic due to it sharp cut offs.
    Difference between Plug n Play Kit HID and True HID w/ Projector
    Apr 2011
    Low Beam
    Hi Beam
    Hi sir Slick, thanks for the reply. Would very much appreciate your update on your project, including over-all cost. May I ask who Garyq is by the way and where his location is? thanks/
    Jul 2006
    Sent you a PM.
    Jan 2011
    Sent you a PM.
    PM me also sir... TIA
    Apr 2011
    Sent you a PM.
    thanks sir slick/
    Sent you a PM.
    sir pa pm din ako.
    Jun 2011
    sir, void ba warranty pag nagpalit ng hid ang gls-v? san po store and how much damage? thanks
2011 Mitsubishi Montero Sport [continued]
