New cars nowadays uses CAN bus system to communicate. The BCM sees an open or too little resistance in the brake light circuit so it will throw a code. Maybe in mitsu system and others, BCM will ask ABS module to light up the abs light to alert the driver.
Old school way is to add resistors to an led bulb or buy BCM friendly led bulbs to fool the BCM.
High tech way is to program the BCM to disregard brake light open circuit detection.
On a side note, check your brake pedal switch as well. Maybe it's not sending brake pedal signal to bcm...
sorry sirs , late reply, for sir baludoy, it has not happened again but am taking the lead of sir zix888, saw a similar predicament on you tube and will look at replacing the suction control valve, medyo mahal, 9500 sa el dorado but replacement pwede diy, thanks sir zix888
bro same problem din ng TPMS ko loss signal all tire, reset ko na sa MID #10 button then remove na rin negative terminal ng battery for 10 minutes, loss signal pa rin ang tpms ko, try ko hanapin yung fuse ng tpms pero hindi ko makita, san ba location non at ilang amp. ang fuse, nakita ko na yung black box tranmitter nya with antenna but no fuse akong nakita
bro same problem din ng TPMS ko loss signal all tire, reset ko na sa MID #10 button then remove na rin negative terminal ng battery for 10 minutes, loss signal pa rin ang tpms ko, try ko hanapin yung fuse ng tpms pero hindi ko makita, san ba location non at ilang amp. ang fuse, nakita ko na yung black box tranmitter nya with antenna but no fuse akong nakita[/QUOTE]
What is the latest map version for our 2011 montero? Sino po ang may copy? Wala na pala sa INAV update site for our unitThanks in advance
Sir, ang auxiliary fan ba natin may hi and may low speed? Minsan kasi mahina at minsan naman mabilis ang ikot ng fan. 1 month old pa lang yung new valeo aux fan. Salamat.
Good day guys, anybody knows where to buy sidemirror? Somebody broke my sidemirror on the passenger side and i dont know where to buy one. Thanks guys -------------------- malmon
Sent from my SM-G965F using Tapatalk
Hi All!!!
Tanong ko lang po kung may naka experience na dito na pag traffic, hindi lumalamig yung aircon? Ayaw mag engage ng clutch ng compressor.. kahit i-rev to 2k rpm, pero pag highway, wala naman problema.. 2011 Monti gen 2 2.5D
hindi na nag-engage yung fan. bro zix shop can easily fix that. then pakabit ka extra fan para may backup kung sakali pumalya yung stock
Nag eengage naman po... pag hindi sinusumpong ok naman... pero pag na stuck na sa traffic, yun na... hindi nag eenggage... thou meron response sa engine (revs to 1k automatically) pero hindi nag engage yung clutch.. then off ko muna, mga 5 to 10 minutes, pag in-on ko na AC, malamig na ulit... hanggang sa sumpungin ulit sa traffic...
