Page 6 of 103 FirstFirst ... 23456789101656 ... LastLast
Results 101 to 120 of 2054
    Jul 2010
    #101
    Quote Originally Posted by normyline22 View Post
    I need a little bit explanation on this one. Explain this in simple math sir Expatio im confused hehe you mean to say that the monty's GC is lower since it has a longer travel suspension? / or to achieve the monty's 215mm min GC you should put on its maximum weight??? so its like the minimum ground clearance regardless of how much weight you put in it is 215?
    Nope Norm; I never said its CG was lower than the SF, I said it was one of the lowest in it's class. I said that its suspension has greater travel, so empty it is a lot higher than the SF as it travels up less; so empty the difference is more than 5mm. But the last bit is wrong
    Explanation: The MS's Ground Clearance actually never changes unless on rough terain (like over ruts in the landscape). This is due to the fact that it has a live rear axle and the axle housing (the round bit in the middle with the diff) always remains 215mm from the road (unless one wheel is in a hole or rutt) and is the lowest point in almost all live axle 4x4s. But the body itself does go up and down and so the CG goes up and down. All vehicles with suspensions' CG changes as it is loaded.
    The SF on the otherhand has independent rear suspension, so its ground clearance as well as CG changes according to weight.
    Jul 2010
    #102
    Quote Originally Posted by ehlemhenopee View Post
    alam ko nga din ngayon ang meeting dun eh jan 25 may thread akong nakitaan na jan25 meeting hahaha... sana kahit price tapos sneak peek ng specs... tapos kahit na march pa roll out pwede na magdown =)
    haha.. ano ba yan ung SA ko talaga dami promises e. kung march pa labas bibili na ko haha.. may promo pa naman SE ngaun un lang wala na mga kulay. kakainis. sabi nia sa feb. 24 daw launching baka lumabas na daw un?? gulo gulo hehe..
    Sounds about right guys. The press get to test drive it on the 18th of February. That is not to say some buyers won't have theirs already in their front driveway before that. Maybe my new BLACK SE will be one of them.
    [SIZE=3] [/SIZE]
    :harp1:
    Black Is Black
    I Want my Monty Black
    Grey is Grey
    Take that away from meeeee
    What Can I doooooooo
    'Cause I, I, I, I, I
    Have got V G T
    :harp1:
    Jan 2010
    #103
    Quote Originally Posted by jces View Post
    mga sir newbie lang po ako sa tsikot. balak ko sana bumili ng montero sport GLX next month kaya lang nabasa ko na meron pa lang lalabas na may VGT. Kailan po ba lalabas ito?at magkano po ito? Worth waiting po ba ang may VGT version na iyan? Thanks and God Speed to all for you.
    Uhmn, If you don't really need the car right now, it is worth to wait for the GLX model with a vgt engine. But one thing is for sure, if the 2011 GLX model with a VGT engine will be released in the coming months, it will cost more as compared to the 2010 GLX model.
    #104
    Quote Originally Posted by nocturnalwasabi View Post
    mga sirs... eto na final spec ng 2011 montero se:
    variant will be called montero sport GT-V 4WD AT
    Engine: 4D56 2.5 turbocharged and intercooled dsl
    Max Power: 178HP/4000rpm
    Max Torque:350Nm/1800 - 3500rpm
    Turbocharger: Variable Geometry Turbo (developed by IHI)
    key spec changes for the Montero GT-V:
    • 4speed INVECS II AT to 5speed INVECS II AT
    • new front grille w/ GTV emblem (Honeycomb)
    • paddle shifters
    • 3-MID system w/ touch screen interface NAVI system, integrated audio functions, DVD playback, iPod, USB, Bluetooth (AVT)
    • carbon fiber rear spoiler
    • tail pipe finisher
    di po pwede ilagay ang VGT sa present Monteros kasi you also have to replace some of the internals. It now uses high strength bearing caps and high strength aluminum alloy pistons, thinner piston rings to accomodate the cooling cavity and high load small and big end con rod bearings
    price... wala pa official from the plant, although may isang dealer who is quoting the 4x2 AT*1.408M. both 4x4 AT and 4x2 AT have the VGT engine.
    units... is already here but it still has to wait until the Feb 24 launching. price will be announced then. same color availability, no introduction of new colors.
    What about the 4x2 variants? I mean specs? Are they the same? I got the same price tag from an SA as well... and another one with 1.410...
    #105
    rumors are spreading that only 4x2 at and 4x4 at will have VGT? Not sure if they will apply it to the GLX since it was only released less than a year?... But then it pays to wait sir waiting until february 24 won't hurt you at all... ako nga 3 weeks ago pa ko commute mode eh.. haha
    #106
    haha what promises ba??? yeah feb24 pa nga sabi nila... But I am guessing march na makakapag-roll out kasi less than a week na lang yun from their launching.. plus for sure marami ng nakapila bago ikaw. bago ako. :P it pays to wait until feb24 for the launching...
    #107
    Quote Originally Posted by Expatio View Post
    So the 5mm difference is only applicable when you put the maximum load on the 2 vehicles. Do I get it right? Sta Fe empty it is will also be much higher than 210? right?
    Geez I slightly understand only a bit hahaha... Anyway to me it looks like the montero is higher than its rivals such as fort and everest. But then it turned out like I shouldn't rely on what I see...
    Jul 2010
    #108
    Isn't this supposed to be 400nm?
    Locoroco, the manual gearbox version will have 400nm.
    Jul 2010
    #109
    • paddle shifters
    Are you sure the SE does not come with reversing camera incorporated in the MMCS (Mitsubishi Multi Communication System) touch screen together with reversing sensors?
    May 2007
    #110
    Yes, locoroco777, Sir Expatio is correct. i thought you knew all along. the torque rating for M/T and A/T are different only that probably MMC engineers can explain. you can even see that on the international brochure that i posted on the TSCP's fb page...
    Dec 2008
    #111
    Sooner or later you will be driving your monty..be a proud owner and enjoy the ride.
    cheers
    #112
    Soon to be owners of 2.5L VGT Monty, you can also visit and join us at:
    http://monterosportclubphil.proboards.com/index.cgi
    http://monterosportclubphil.proboard...ay&thread=1612
    Sep 2009
    #113
    • paddle shifters
    • audio functions, DVD playback, iPod, USB, Bluetooth (AVT)
    nice! sir? how about the interior? may pag babago ba? like the 4x2 a/t naka auto climate na din b?
    Sep 2009
    #114
    haha.. pano b nmn sbe sakin first week of feb daw. haha.. buti na lang ttlga nag babasa ako dito nakakaupdate ako.. galing
    Jan 2010
    #115
    sana sir MS 2.5 m/t GT-V ganito din specs niya...
    pero masType ko yung lumang front grille, yung hndi honeycomb...
    • paddle shifters
    Jan 2011
    #116
    So ma'am kh8? lahat ng variants magiging VGT aantayin na lang maubos yun remaining na GLS nila??? let's just say 1.380m yun GLS a/t how much kaya itataas nito pag VGT na?
    wala pa bang date kung kelan formal announcement?
    sir lalaki po ako..hehe..lahat sir ng variant ng 2011 vgt na,ang dinig ko lang eh 1.7m plus yung 2.5gls gtV 4x4...wala pang date kung kelan talaga ilalabas..pero yung mga dealer is accepting reservations na...
    Jan 2010
    #117
    Quote Originally Posted by kh8_montero View Post
    how about sir yung 2.5l GLS GT-V 4x2 M/T sir?
    my specs na ito sir?
    Jan 2010
    #118
    wow! really best value for money ang bagong montero with the reasonable price increase. it will truly be a hotcake in a few months. hope na di bigyan ng priority those in-house or casa financing buyers as compared to those cash and bank financing buyers. Just my 2-cents, no offense po to those concern people.
    Jan 2011
    #119
    yung 4x2 at gls also has paddle shifters? or only the 4x4 gls se?
    and is this for all a/t models or only the SE?
    paddle shifters
    tail pipe finisher
    #120
    :harp1:
    Black Is Black
    Grey is Grey
    Have got V G T
    :harp1:
    Sir Expatio are you one of us waiting for the VGT?
2011 Mitsubishi Montero Sport [ARCHIVED]
