Sooner or later you will be driving your monty..be a proud owner and enjoy the ride.
cheers
cheers
mga sirs... eto na final spec ng 2011 montero se:
variant will be called montero sport GT-V 4WD AT
Engine: 4D56 2.5 turbocharged and intercooled dsl
Max Power: 178HP/4000rpm
Max Torque:350Nm/1800 - 3500rpm
Turbocharger: Variable Geometry Turbo (developed by IHI)
key spec changes for the Montero GT-V:
- 4speed INVECS II AT to 5speed INVECS II AT
- new front grille w/ GTV emblem (Honeycomb)
- paddle shifters
- 3-MID system w/ touch screen interface NAVI system, integrated audio functions, DVD playback, iPod, USB, Bluetooth (AVT)
- carbon fiber rear spoiler
- tail pipe finisher
di po pwede ilagay ang VGT sa present Monteros kasi you also have to replace some of the internals. It now uses high strength bearing caps and high strength aluminum alloy pistons, thinner piston rings to accomodate the cooling cavity and high load small and big end con rod bearings
price... wala pa official from the plant, although may isang dealer who is quoting the 4x2 AT*1.410M but its not official yet. both 4x4 AT and 4x2 AT have the VGT engine. 4x4 MT will have the 3-MID system, 4x2 MT is unchanged
units... is already here but it still has to wait until the Feb 24 launching. price will be announced then. same color availability, no introduction of new colors.
[quote=nocturnalwasabi;1664016]mga sirs... eto na final spec ng 2011 montero se:
Max Torque:350Nm/1800 - 3500rpm [SIZE=3]-- ang baba pa din nito ah. Navara 403 na eh.almost same HP.[SIZE=1]
[/SIZE]
[/SIZE]Turbocharger: Variable Geometry Turbo (developed by IHI)
mga sirs, eto lang po ang mga spec change sa 2011 montero on all variants plus the tailpipe finisher. nothing more, nothing less.
for internal consumption lang sana ng MMPC itong doc na ito. but i guess you guys deserves the info.
pasensya na mga sirs. i had a hard time uploading with photobucket yesterday eh.
Quick comparison with 2010 or older - - the 2011 has more horses, is that a new engine?, touch screen AV LCD with GPS (is that what I think it is?) reverse camera, plus a lot more . . . Why is it cheaper? I planning to buy this one vs the Fortuner or the everest unless there is something we don't know yet? I got the specs below in case you havent seen them yet.
: 2011 MITSUBISHI MONTERO SPORT GLS 2.5 VGT 4X2 Diesel A/T
2477cc 4D56 DOHC 16-valve EFI Variable Geometry Turbo (VGT) with Intercooler CRDi diesel engine, 178ps/4000rpm maximum horsepower, 35.7kg-m/1800 to 3500rpm, 4-speed INVECS II Automatic Transmission w/ Sportronic Mode, 3-spoke leather wrapped steering wheel w/ integrated audio control switch, MMAD single-in-dash DVD/MP3/WMA/MPEG4/tuner/USB port/iPod ready/Audio Jack/Bluetooth connectivity/Reverse Camera ready/7” touch-screen LCD monitor with integrated Multi-Information Display (MID) and Navigation System, manual controlled air-conditioning system, Dual front SRS airbags, 16” front disk/11.6” rear drum brake system w/ ABS and EBD, double wishbone coil springs front suspension w/ stabilizer bar, rear 3-link coil springs suspension with stabilizer bar, 7 adult seating capacity, black water repellant fabric seats, manual (slide, recline and height adjust) driver seat, power windows, power adjust side-mirrors w/ one-touch auto-fold function, color-keyed tailgate garnish, tailpipe finisher, keyless entry alarm system, 265/65 R17 tires on 17” x 7.5J alloy mags wheels, CEDP, 3 year anti-rust warranty and other standard factory specifications.
