Page 81 of 149 FirstFirst ... 317177787980818283848591131 ... LastLast
Results 801 to 810 of 1485
    Aug 2007
    #801
    Quote Originally Posted by 10640142 View Post
    mitsu cdo (fast autoworld) tel: (6388) 855-5394 (trunkline)
    (6388) 855-5393
    may cellphone number ako sa SA ko, pm me lang.
    may pm ako sayo sir!
    Jun 2009
    #802
    try to contact xavier 09325341619. He's a TSCP member and an active tsikoteer
    Thanks... will do.
    Just visit a showroom. Useless and email in a 3rd world country like ours...
    I plan on visiting one soon...
    Sadly, what you said is true.
    #803
    mga sirs,
    i just want to ask how to reset the tire pressure monitoring system(TPMS) of the strada, my friend said to just pullout the positive or negative cable from the battery for a few minutes and then put it back....is this correct or is there another way?? i dont know if it worked when i did it yesterday...
    Apr 2010
    #804
    Hi mga BOSB, Just would like to know where i can get a replacement for the fender flare rubber trimming same as the one installed in the original flarings of the GLS version of Strada. This is the rubber seal between the body and the fender flare. I have a GLX and had a fender flare accessory installed by the Casa. The problem with the rubber included is it is thick and the rubber is slowly deteriorating, parang natutunaw na lalo na kung naka park under the sun lumalambot na yung rubber at pati dumi dumidikit na. Now it looks dirty with black rubbery gum... :-( TIA for your help.
    Aug 2007
    #805
    Quote Originally Posted by janrye26 View Post
    anybody knows how to trouble shoot this problem? d na mawala sa odometer. thanks. palagi lang naka ilaw. bka may naka experienced na sa n u mga sir!
    I had the same experience before..after installing a new horn or side mirror lights...
    When I went to get the periodic service, the CASA just resetted it i supposed.
    Aug 2007
    #806
    Quote Originally Posted by KCboy View Post
    mga sirs,
    When my spare tire was stolen before, I had to get a new one, and the CASA 'initialized' again the TPMS. its quite tricky since the TPMS computer needs to detect each tire in its particular position by inflating and deflating each one.
    Oct 2004
    #807
    Quote Originally Posted by epsycho View Post
    Saw some rubber trimming at Robinsons Handyman. Black at grey at ang available colors.
    Aug 2007
    #808
    Quote Originally Posted by DonT View Post
    yes got it when they installed my side mirror din. good to hear na ma reset lang nila. kaso wala casa ng mitsu dito sa amin bt may nagka caravan dito twice a year. ill call pa mitsu cdo if when next sched nila here. thanks sa assurance boss.
    Jun 2007
    #809
    mga sirs,
    Try this
    - engine off
    - press botton in TPMS
    - Put key to on/start position but remember "DO NOT RUN ENGINE"
    - TPMS start flashing (re-program)
    - done
    if not succesful...call Winterpine
    May 2008
    #810
    mga sirs,
    inflate all tire to 50psi minimum including spare tire
    1. press the red button (mode) and turn the ignition on at the same time
    2. release the button when 001 appear and 1st tire flash (front left)
    3. deflate the front left tire until buzzer beeps and the led turn green then 002 appear and the 2nd tire flash (front right) and so on until to the spare tire.
    Note: programing time is 2 minutes, if not completed within 2 minutes wait for 5 minutes to do reprogramming.
2010 Mitsubishi Strada [continued]
