Page 5 of 8 FirstFirst 12345678 LastLast
Results 81 to 100 of 1362
    Quote Originally Posted by EuroFD View Post
    I just had my 20Tkms PMS done at Diamond Cars Fairview. I brought my own synthetic oil. Casa charged me P11,600+ for parts and labor. I would've saved a thousand more if I bought the filters (oil, fuel and air) at El Dorado. HTH
    sir if not too much to ask, pwede ba sir pa-post ng breakdown nung 11600 na charge? tia
    Apr 2011
    Quote Originally Posted by zix888 View Post
    had my 20k pms at las pinas citimotors
    total charge was p12,238
    Jan 2010
    my casa receipt for 20k km pms + 7 quarts of RP oil worth 3,950 pesos
    Sep 2010
    Hi peeps! Looking for a home for my Monty.
    Sep 2009
    Hi guys. Bigla na lang nag-aalarm yung Montero namin kapag nakapark. Wala namang kumakawang na pinto or kahit ano. Ano kaya ang cause ng pag-trigger bigla ng alarm? Thanks!
    Jan 2010
    Quote Originally Posted by retsuyaken View Post
    seems a shock sensor... I think it needs replacement, it happened to my unit last year, that sensor was replaced...
    Quote Originally Posted by rmsoriano View Post
    isolate mo muna, lower the sensitivity, or disable momentarily yung shock sensor and check kung mag a-alarm pa rin.
    Apr 2013
    Mga Sirs good day. Meron na po ba nakapag palit ng head unit sa mga d pa naka 2 din? San po ninyo nilipat yung mid nyo? If dun sa may dating lalagyan ng stereo meron po ba kailangan sirain sa dash para mag fit yung mid? Thanks mga sirs!
    Sent from my Starmobile ASTRA using Tapatalk now Free
    Nov 2012
    Hi, what is the possible problem if there is oil leak in my engine? I already filled it up with half liter but after a week i noticed it was way down the gauge limit. Could anyone help? TIA
    Bump ko lang po young question na to from 2013.
    Planning to replace the head unit to 2-din and relocate the multi info display sa old location ng single din na head unit.
    Sa mga nakapagpagawa na nito:
    1- Pwede po pa-share ng picture?
    2- Saan po kayo nagpakabit?
    3- Magkano po inabot?
    Salamat po.
    Quote Originally Posted by eyron View Post
    Aug 2005
    Mga peeps, ask ko lang kung how much resale value ng monty 2010 GLX MT?? Mileage: 26,000+ km. Binebenta kasi ni utol. Any ideas?
    Quote Originally Posted by leinahtan View Post
    Wala po ba "driver error" issues yan?
    Sa olx ang bentahan nasa 640k up.
    Ay manual po pala kaya safe ito😆
    Apr 2010
    *solgen
    Is there a visible leak?
    Would you know where it is exactly coming from? If can't locate, your car needs engine wash to identify where it is coming from.
    If there is no visible traces of oil, make sure to make the oil readings/checks on the same parking spot and on similar amount of time after shutdown. Oil level is diff right after shutdown and in the morning before using the car..
    hth.
    Apr 2013
    Good pm mga sirs. Baka merong nagpalit sa inyo ng plate holder bilin ko na lang yung oem plate holder nyo. Thanks!
    Apr 2013
    May nakapag try na po ba sa inyo maglagay ng DTP ultimate chip sa monty?
    Kamusta naman po?
    Apr 2010
    Up up up up.........sa mga naka pag blanking egr ok naman po ba?....tnx
    Jan 2013
    i had my egr blank.. so far so good.. less smoke, more responsive.. more than 5k na natakbo, no problem naman.
    Sep 2010
    Anybody here having problems sa steering column nila? Im hearing knocking sound. Sabi ng SA ko sa steering column daw. Lailangan na palitan.
    2005 Honda GD13 Jazz / 2010 Mitsubishi Montero GLS
    May 2009
    Guys,
    Any idea of the kind and make of this mags and where it can be sourced out locally?
    Thanks much!
    Rev
    Aug 2011
    Quote Originally Posted by urbanhopper View Post
    Silent recall yan sir. Sa akin 2009 model napalitan na last 2 years ago.
    Posted via Tsikot Mobile App
2010 Mitsubishi Montero Sport [continued]
