Page 6 of 58 FirstFirst ... 23456789101656 ... LastLast
Results 101 to 120 of 3019
    hello po,
    sino po naka bili dito ASX during the Christmas promo nila? yung may free macbook air or ipad2 or low downpayment...
    kasi naka bili ako ASX pag december tapos ang tagal binigay nila ang free macbook air... until now dami pa reasons yung salesman ko... iba2x lang reason nya...
    san po tayo maka bili mga accessories para ASX? especially for the front grill, GLX lang kasi sa akin.
    Quote Originally Posted by zix888 View Post
    Sir actually yung nitrogen ang maappreciate mo lang is yung medyo matagal ka bago magdagdag ng pressure ulit. Pero yung factor para maging sobra bumpy kasi naka ordinary air ka kumpara sa naka nitrogen is hindi rin naman masyado. I had been monitoring that behaviour of nitrogen since 06 mula ng naglow profile tires ako, nagkabit nako tire pressure monitors, even sa pinakamatagal na bihaye ko, maximum lang of 1.5psi ang lamang ng nitrogen in change in pressure compared sa ordinary. Lets say before biyahe, ordinary and nitrogen pressures both 30, after long drives of 5-6 hours ordinary 34psi and nitrogen 32.5psi, so para sabihin mo na malaking malaki ang diprensya, i dont believe that. If its free sa mga shops as okay lang, pero kung pricey, ordinary air ka na lang
    Actually, nung nag palit ako ng 20s sa montero napansin ko na medyo gumaangan yung steering niya nung nag pa-nitrogen ako. Not sure if talagang gumaang or psychological lang yun. Yung ride stayed the same. Although I seldom do long drives for me to notice yung difference... Long traffic everyday.
    Well will monitor yung impovement nung ride since I checked the tire pressures this evening. Medyo matigas nga yung harap at likod. Hopefully maging ok na siya. I'll use it tomorrow part masigurado ko na yun lang talaga yung problem.
    Thanks!
    Dec 2011
    For tire Nitrogen believers, here's the fact;
    The air we use everyday composed of, 78% Nitrogen, 21% Oxygen & 1% other gases.
    The claim of Nitrogen for tire is not 100%, unless you are totally in a vacum from production to inflating into the car tire.
    Roughly, you just buy 15% Nitrogen for almost 400Pesos for 4tires.
    Finally, the benefits are????
    And you become reluctant not to check your tire regularly, later to find out your tire is 10Psi lower because of puncture...
    Oct 2011
    Quote Originally Posted by F-14 View Post
    The benefits? from what i understand and read, lesser or totally no moisture due to the added nitrogen, thus oxygen is minimal to negligible.
    Dec 2011
    Still no real benefits!
    Less to zero O2 = less to no oxidation, for tire, for mags?
    Youre trying to protect the inside, how about the outside of the tire & mags?
    Less to zero O2 = almost stable pressure, for what?
    Under full load, long drives, short drives, with off road driving, city drives. These all need to adjust tire pressure accordingly if youre really concern with your tires.
    Using a Nitro unless you are a car racer or a jumbo jet fighter, really no substantial benefits to our car.
    Kaya advice ko nga sa mga tsikoteers na if free lang siya, okay lang, pero para magbayad pa just for that, pang alis guni-guni lang, huwag na lang. Pero kung free, definitely would use that kaysa ordinary air
    Anyways, mukhang ganun nga ata talaga ang ride ng ASX. Nanibago lang ako siguro. About the knocking sounds naman, they told me sa casa that there might be some problem in the multi link suspension at the rear (same daw sa naencounter sa GTA). They did some re-thighening and i-observe ko daw kung mawawala yung tunog. Sana mawala na siya.... Kung hindi pa rin mawala yun mukhang mag stay ako sa 17s hanggang maging ok to...
    Thanks mga Sir!
    Oct 2011
    walang pinagkaiba ito sa mga engine treatment.
    Dec 2011
    Yup, I agree.
    Oct 2011
    That is also what I thought bro.
    Update ko lang yung knocking problem na sinabi ko a few pages back... Mukhang hindi related sa suspension! It looks like isa sa mga gulong hindi mahigpit yung lug nuts (well yun yung theory ko). Nag palit kasi ako ng rims and the knocking sound sa likod nawala na. So hopefully yun lang yung problem. But the thought na ganun medyo natakot din ako since never don't usually check the lug nuts ng gulong. Baka bigla na lang yun tumalsik pag mabilis takbo ko. Anyways, happy ASX owner na ko.
    Ok Bro, dapat SOP yun sa mga gulong. Either palit ng rim, vulcanize, PMS... Basta binaklas ang gulong ay dapat counter check yung higpit ng mga nuts. Mas ok kung may tourque wrench.
    Mostly maka-experience ka talaga ng shortcomings ng mga mechaniko kaya dapat aware tayo sa mga kilos nila.
    Quote Originally Posted by Noel Salisipan View Post
    Agree.
    Pero yun lang, nilabas ng CASA sa kin yung unit na may knocking sound na and I never checked if mahigit yung mga lug nuts. And I don't think na binaklas din nila yung mga gulong nung nag 1000 PMS ako. So its been loose from the very start siguro.
    Quote Originally Posted by dg1110 View Post
    Agree.
    Possible Bro, kaya dapat ingat tayo.
    Experience ko rin yan nung 10k PMS ko, nung inalis yung gulong para linisin ang break e pag uwi check ko mga nuts. ayun, dalawa ang maluwag!
    Dec 2011
    GLS owners. na try nyo na ba i fold yung side mirrors? Parang nakakatakot. haha. Parang ang tibay kasi ng kapit.
    Jan 2008
    question lang mga sir. how much yung cost ng 10km pms? mag 10km na kasi asx ko. thanks sa mga mag rereply!
    Quote Originally Posted by sole_gemini View Post
    Yup, I fold my side mirrors every now and then when I need additional clearance around the car. Takes a bit of effort to start it to fold.
    Ok lang yun bro khit back & fort.
    Para lang may nabaling buto.hehehe
    Feb 2011
    ano po ba ang wala sa gls kumpara sa SE salamat
    Quote Originally Posted by Alancer View Post
    Ayan na Bro, right above your last post!
2010 Mitsubishi ASX Crossover
