Page 20 of 58 FirstFirst ... 1016171819202122232430 ... LastLast
Results 381 to 400 of 3019
    May 2011
    my reply in red...
    Quote Originally Posted by Pipefish View Post
    Specifically, I want to know if the 2012 GLS has a parking sensor *YES and reverse camera *Dealer option, but they'll drill your bumpers! The one shared with the OEM plate light like mine & GH - we ordered it from China. Am I right to assume it doesn't have Hill Start Assist and Active Stability Control? Yes, GLS SE only It does have On/Off and Cruise Control, right? Yes Any other differences? Thanks in advance.
    P.S. Meanwhile, I was told the GLS SE doesn't have a sun roof, unlike its counterparts abroad.
    Sent from my GT-N7000 using Tapatalk 2
    i just downloaded the GLS brochure from mmpc site: http://www.mmpc.ph/asx_gls/brochure.pdf
    i don't see any "outdated" info there... care to elaborate your expectations?
    Aug 2012
    I've done that and it's an old version of the ASX brochure.
    Aug 2012
    Quote Originally Posted by skybison View Post
    my reply in red...
    Thank you. About the brochure, for one, it says "keyless operation + engine start/stop button" is limited to the GLS SE.
    My sales agent also insists the GLS also has HID headlamps. Is this correct? Thanks for your help.
    Might as well ask you this: I suppose you're referring to this reverse camera:
    Ebay link
    The seller claims this CCD camera is better than the usual CMOS type. Does it have a built-in light to replace the ASX's built-in plate light? It's not obvious in the picture.
    I'm also thinking of getting a side camera (I'm a newbie driver and want to see what's on the right side) =B) Will something like this work?
    Ebay link
    It's supposed to be installed under the side mirror, but how exactly will the cables go inside the vehicle? Thanks!
    Ebay link
    The ASX back camera fits into a pre-cut hole on the left of the license plate area. You do not have to remove any of the existing license plate lights. The hole is currently covered by a plastic piece.
    Aug 2012
    Do you still disconnect power from the ASX's built-in license plate light and replace it with the camera's built-in light?
    Which of the configurations on this page do I choose? Port A or Port B?
    I'm still confused. Thanks.
    The one you have in your link replaces one of the original license plate lights.
    Try looking at these:
    LINK: Car reverse camera for Mitsubishi ASX , rear view camera Free shipping-in Parking Assistance from Automobiles & Motorcycles on Aliexpress.com
    LINK: Mitsubishi ASX Car Rear view camera Reverse camera Backup parking camera with 170 degree view angle waterproof Night Vision-in Parking Assistance from Automobiles & Motorcycles on Aliexpress.com
    Power for the camera is taken from the license plate lights. Just tap the existing wiring.
    Aug 2012
    Thanks. Any other differences? By the way, when did the 2012 ASX come out here? I'm still thinking whether I should wait for the 2013 version.
    Jan 2010
    Sirs:
    Ask ko lng po your experiences about the ASX's noise in the cabin. Like how is it on city driving or when you go more than 80kph? or at what speed is the noise already wanna make you slowdown?
    I'm asking because I saw youtube videos saying the noise is something worth looking into for the ASX. i like the 'nguso' design besides my assumption that its a good air intake but i just worry this further intensifies the already noticeable noise inside.
    or if someone can compare it with a honda jazz in terms of noise level that would be helpful too.
    Thanks in advance.
    Quote Originally Posted by bosjef View Post
    Sirs:
    No experience on my part & no issue from this forum!
    150kph ang max speed ko pero walang irritating noise, ilang beses ko na ring naidaan sa unpave road at ilang beses na rin akong nalubak ng medyo malakas. So far, ok naman.
    May 2011
    tried 170 *SCTEX, ok pa naman.
    195kph on NLEX/SCTEX ... no problem with engine nor road noise.
    Sirs:
    Thanks in advance.
    Used to drive a '09 civic 2.0S and for me medyo mas maingay lang yung engine ng ASX when you reach high RPM. Pero the fastest I hit in my ASX is around 140kph pa lang. The civic I was able to hit 165. City driving, pretty much the same.
    Try to do a test drive. Overall I think ASX is a very good CUV. (Yung harap din ng ASX yung gustong gusto ko kaya eto yung kinuha ko)
    Jan 2010
    Thanks for all the responses! More power!
    Aug 2012
    Thanks. I was hoping to get one with a CCD sensor. The instructions from these sellers are so confusing because they seem to be copying from each other, including all the inaccuracies.
    May 2011
    careful ka with those sellers from china, you have to be detailed on your orders
    for the installation of my rear cam: page 175, http://tsikot.com/forums/mitsubishi-.../index175.html
    here are a few pictures for better visual understanding..
    i wont be recommending yun nabili ko IF you plan to buy deflector brand na car plate cover
    you need some creativity to cut off some areas to give way to the camera... otherwise tatama.
    unless meron na nito si winterpine...
    Aug 2012
    Thank you, I'll get the black one then. Appreciate the photos.
    Apr 2010
    My cable just arrived for customizing the ecu's. Ill post Tom if I am able to turn on the auto lock on 20 kph and auto unlock on engine off or park.
    Aug 2012
    Mga boss, nabanggit ko na balak ko kumuha ng ASX sa katapusan ng buwan. Approved na 'yung loan ko at nag-submit na 'ko ng requirements sa bangko, pero di ko pa binibigay 'yung pangalan ng dealer dahil kino-compare ko pa sila.
    Ayaw i-free ng Peak Motors Manila Bay 'yung reverse camera at ayaw din magbigay ng free installation kung galing sa labas 'yung camera. Mavo-void daw warranty since electrical.
    May kausap din akong sales agent sa Diamond Motors sa Quezon Avenue pero di ko pa naitatanong kung nagi-install sila ng accessories na di binili sa kanila. Nakabili na kasi ako sa Alibaba ng reverse at side cameras (bagitong driver ako). Gusto ko sanang makakuha ng free installation para hindi na 'ko gagastos. at sa dealer ko sana ipapa-install para walang problema sa warranty kung sakali. Sinisingil ako ng P8,500 ng Peak para lang sa reverse camera na galing sa kanila. No way.
    May nabasa ako sa thread na si Utoy sa Diamond Motors Alabang, marunong mag-install. Official installation ba 'to? Sino kaya pwede kong pagtanungan dun kung pwede ipa-install sa kanila ang cameras na nabili ko sa labas? Kung pwede, malamang dun na 'ko kukuha ng auto. Iba-iba ba ang policy ng mga dealers tungkol dito? Aling dealers ang maisa-suggest n'yo? Salamat.
    May 2011
    like been discussed before, bring your "gadgets" to winterpine araneta if you want to retain your warranty on electricals. Exclusive distributor of Mitsu Head Units & some accessories.
    Rear camera's will be easy for them, not sure with your side cameras.
    for ASX, camera's mine, paid labor for installation p500 (+100 tip to the installer)
    for Montero, i paid 5,400 for the camera & installation (+100 tip to the installer)
    meron talagang ibang owners na malalakas ang loob magpa-install sa ibang auto/electrical shops (non-accredited by MMPC).
    I just hate the argument/debate in case there might be problem arises on electrical warranty.
    minsan pa nga busina lang i-void na nila warranty.
    Eto naman position nung Camera ko for my personal reasons kaya di ko pinalagay sa gawing labas at taas ng license plate,
    eto yung output,
    comparison naman dahil tinted din yung rear windshield
    comparison din pag sa labas kuha (same exposure at setting yung huling tatlong shots)
    Kontento naman ako at mas nagrerely pa rin ako sa "reverse sensor"!
2010 Mitsubishi ASX Crossover
