Hello kailan ko po malalaman if kailangan ko ng magpalit ng timing belt component (my car is GSR 2001 model) and how much usually cost nito?
Yung oem na goma sa casa mo lang mabibili yokohama 215/45/r18, usually ang inilalagay sa stock na gta is 225/40/r18, madami sa sulit nagbebenta nun iba ibang brand starting at 4k/ea
Usually ang bntahan is per set of 4 d kasama spare.
Saka ka na magpapalit, pudpudin mo muna goma mo sayang eh
Pano po pag na flat ung isa, pwede bang spare ang 16" na stock ng GLX then ung 3 gulong is stock 18" ng GTA?
ano po ba ibig sabihin nitong mga sukat na to? - 215/45/r18
Balak ko din po kac magpalit ng 18" stock rim and tires ng GTA pag kabili ko ng GLX.. kaso puro 4pcs/set nga ung nakikita ko..
what are the available colors for the MX variant? May blue po ba for MX? and pls enlighten me po, parang i saw in the MLPH forum a blue lancer na yung shade nya is like that of elantra's santorini, repainted po ba yun? Thanks
Kinetic blue is only limited to the top of the line variant, GT-A. The Lancer EX Ralliart and Evolution X also comes in blue.
Yung common colors ang available sa MX - black, white, red, silver.
nice read para sa mga kakabili lang ng ex
Speedlab - How to Turbocharge Your Car
Nitrous oxide and turbocharging are two different things but they do the same effect on your car... increases your engine's horsepower.
... now can it be done on your EX 1.6? ... yes, it can be done BUT the HP gain will be lower. At best, your 1.6L engine might do around 150hp or roughly the same as the stock EX 2.0L.
If youre going to turbo charge it, mas ok na diretsoka na s 2.0. at mas ok ang performance n maeextract mo s 4b11 against 4a92. Reminds m of a previous post regarding sentra mods. turbo ga16 vs a stock sr20
Yes or even more because an aftermarket turbocharged engine will run better/safer with a slightly rich mixture. BUT that is when you are using its max potential. When you are just driving "normal" or off-boost, you will have the fuel economy close to your stock 1.6L engine.
So overall fuel economy depends on how much you will feel the need for speed.
A turbocharger is a part of the engine. It takes the exhaust gasses and uses it to compress intake air to be fed into the engine. It enables the engine to make more power.
"off-boost" is driving your car below the RPM before the turbo engages or provides boost. Example, if the turbo starts to boost at 3000rpm, to drive "offboost", you will have to keep below 3000rpm.
More info about turbocharging: HowStuffWorks "How Turbochargers Work"
