Results 1 to 3 of 3
    Hello Guys,
    Need your help,
    Bought a lancer mx 2001, everthing else is seems to be ok,
    but ive noticed that everytime im about to stop (or knob on D while stepping on the brake), the engine is greatly vibrating as if mamatayan. RPM down to 500, same as pag liliko.
    I ve searched for threads here and saw that the MAF and IACV needs to be cleaned? would this somehow solve this problem?
    I have a manual GLS and it doesnt have this problem.
    Any input guys would help.
    Thanks,
    Did u just replace your battery?
    If you did, just drive normally, ecu will relearn everything.
    Sir Istan,
    Ang sabi nung first owner ay nag palit nga sya, about 3 months ago.
    Sana nga by this time na re-learn na ng ECU yung change.
    So what i did is reset the ECU, disconnecting battery then reconnected, then let the car run for 10 - 15 minutes. so far the symptom is still there, bumababa yung idle approaching a stop.
    Thanks,
2001 Lancer MX Vibrates when about to stop
