Results 1 to 15 of 15
    What specific rpm does the turbo of a 4D56 intercooler turbo kick-in? Low pressure or high pressure ba turbo niya?
    Thanks.
    Jul 2003
    ewan
    It starts working around 2K rpm. It does not really kick in, it gradually builds up pressure. Basta sufficient na ang exhaust pressure.
    Low pressure turbo. stock boost is 8psi as far as i can recall.
    Mr. Roydok, you may know this already but I learned from the shop where I had my Space Gear's injection pump overhauled, the injectors in a strada is the most expensive among the mistusbishi diesels. Mine cost Php850/piece but for the strada it costs Php1.4K per piece! for your info.
    Thanks guys.
    Jul 2004
    is the 4D56 engine in the montero sports basically the same as the 4D56 engine in the adventure?
    are the parts interchangeable?
    Aug 2010
    AFAIK, some parts siguro kasi yung new gen 4d56 is dohc a D-id Common rail vgt na,, yung sa adventure is a n/a 4d56 sohc
    the turbo setup and the overhead cams palang, malayo na sila, although they have the same engine code, baka sa seals and engine block lang ang same..
    ^ strengthened engine parts (piston, rods, bearings din yung sa crdi) as per MMC mismo.
Mitsubishi 4D56 Turbo Questions
