Results 1 to 20 of 24
    Just your thoughts on using Asphalt Shingles Roofing. Your Rants and Raves. The Advantage and Disadvantage. Your queries can be answered here..
    Contrary to other beliefs that shingles are very expensive, i would like to explain further that it's inexpensive considering that shingles roofing is a long term investment. First and Foremost, when you build your dream house you want it to be perfect. Something that can give you peace of mind. Something that can rejuvenate you ,something that will recharge your energy lost during a long days work. Having a warm or should i say hot temperature inside your home makes this all impossible to achieve except when you use an aircon. This is where shingles roofing come into place. Shingles Roofing doesn't only make your home cooler it also helps you save much on electricity. It also makes your home more elegant looking. Imagine this, Long Span Vs. Shingles Roofing. The Life Span of Shingles can surpass Long Span 2-3 times longer. You don't have to worry about the maintenance coz you don't have to re-apply paint and you don't have to worry much about leaks when you use Shingles. Aside from this, shingles have a manufacturer's warranty of 30 years. If the shingles have defects during the 30 years warranty,the manufacturer will replace it free of charge. Plus, there is also a 10 years WORKMANSHIP warranty from the installer separate from the manufacturer's warranty. If you got queries, i will be here to answer the best way that i can.
    Oct 2007
    How much it cost for a nomral 150 qm floor area?? meron na ba sa pinas nito? sino dealer
    http://www.asphaltroofing.org/
    Sir,it will depend on how steep the slope is. Some of the computation will be based on the actual steep of the slope. The steeper the slope the higher the labor cost. Philippines started to have shingles roofing since 1997 but only now lang sila napapansin..
    Oct 2007
    ^^^why can't you give a ballpark figure? so we could actually see how much the price is...
    backspace gave the figures 150 square meter, regarding the slope what is the minimum allowable slope? based the price on that..thanks
    PM sent for Shadow and BackSpace. For inquiries regarding shingles quotation and estimates, just send me a message here. I will be glad to assist you. Thanks
    Ewan ko kung nakita nyo na ito. Yun bang nasa TV/print ads ng Avida Settings, asphalt shingles ba ginamit dun?
Asphalt Shingles Roofing.. Cool and Elegant
