Results 11 to 20 of 23
Tsikot Member Rank 4
- 2,719
August 7th, 2012 04:57 PM #11noong nag-leak ang bubong namin, bumili ako sa ace hardware ng waterproofing paint, meron syang kasamang mat (parang fiberglass) na ilalatag habang basa pa ang pintura at lagyan uli ng layer ng pintura ... efective naman
August 8th, 2012 12:14 AM #12
Aah, abroad pala.
But yes, when youre building or renovating a house, mainam talaga to go overboard on weatherproofing it. Build high above streetlevel, waterproofing on the walls, steep roof, large gutters and drains, covered parking and areas around the house, etc. Laking bagay during the wet season.
- Nov 2009
- 1,756
August 8th, 2012 11:52 AM #13
- Nov 2009
- 1,756
August 9th, 2012 10:01 AM #15
August 11th, 2012 08:30 PM #16
How long does the waterproofing membrane last? hindi rin biro ang presyo ng waterproofing membrane.
August 12th, 2012 07:49 PM #17
- Nov 2009
- 1,756
August 13th, 2012 07:40 AM #18
August 13th, 2012 11:12 AM #19
Ok lang ba sa firewall na imbes na waterproofing paint, balutan nalang yero yung buong firewall at pintahan ng waterproofing yung yero? para doble sigurado?
August 13th, 2012 07:41 PM #20
if your problem is water seepage and to add unwanted heat specially if the firewall is on the west side, you can opt for steel brackets/frames where you can fasten the tin roofing material as a heat shield and as a water shield. just make sure that the top has a really good flashing or cap to prevent the water intrusion between the now installed heat shield and the concrete firewall.
Sa local market ng automobiles, mostly uso yung paying more for less. Yung stripped ang maraming...
China cars
